I'm trying to monitor my OpenVswitch via IPFix. But I'm banging my head against a brick wall for two days now :/
According to the ovs-vsctl manpage I need to add a new entry into the config-database, more precisely into the "ipfix"-table. That worked pretty well, and it looks like I got it right:
# ovs-vsctl list ipfix
_uuid               : 2d54982b-6cc5-4a8c-845c-cc7ef701da01
external_ids        : {}
obs_domain_id       : 123
obs_point_id        : 456
sampling            : 64
targets             : ["<collector-ip>:<port>"]
I then downloaded libIPFIX and started the example_collector. But nothing shows up. I don't receive any information. I confirmed it using wireshark ...
Some Google-Research brought up an eMail from the Mailinglist, which states that one needs
OpenFlow actions to cause IPFIX to be sent to the collectors
According to this eMail there are new "sample actions", but I couldn't find any further information how to add them.
My best guess is that I'm missing these OpenFlow Sample-Actions. Can anybody provide me with information how to add those?
/edit: I'm running OpenVswitch Version 1.11.0 on openSUSE 13.1 (x86_64).
To get IPFix to work I tried the following:
# ovs-vsctl -- set Bridge s1 ipfix=@i -- --id=@i create IPFIX targets=\"10.0.0.1:4739\" obs_domain_id=123 obs_point_id=456 sampling=64
To confirm that I did the ovs-vsctl list ipfix (see above)
A similar command worked as expected to get sFlow to work:
# ovs-vsctl -- set Bridge s1 sflow=@sflow -- --id=@sflow create sflow agent=eth0  target=\"10.0.0.1:6343\" header=128 sampling=32 polling=2
0df2b92b-8a83-4a63-acc4-fecf6f8f492f
Right after entering that line, I got sampling results send to my target computer. Unfortunately no luck with IPFix.
    @ChristophHaefner What are your log files saying when you pass the failing IPFix command? – Ryan Foley Jan 22 '14 at 08:36
    @Fizzle: Thanks a million for the hint. I was search previously for log-files, but /var/log/openvswitch/ was empty, so I moved on. But with your push I searched more sophisticated and found a log-file: /var/log/ovs-vswitchd.log! And it's actually stating that he tries to deliver: "2014-01-22T10:09:04Z|1017630|collectors|WARN|sending to collector failed: Connection refused" Must have overlooked it while debugging with wireshark :/ – Christoph Haefner Jan 22 '14 at 09:12
The verbiage you're using to setup IPFix is definately right.
This is what you have:
And pretty much the same example is outlined in the ovs-vsctl man file:
IPFIX
Configure bridge br0 to send one IPFIX flow record per packet sample to UDP port 4739 on host 192.168.0.34, with Observation Domain ID 123 and Observation Point ID 456:
ovs−vsctl −− set Bridge br0 ipfix=@i −− −−id=@i create IPFIX targets=\"192.168.0.34:4739\" obs_domain_id=123 obs_point_id=456
Based on your log file in the comments section:
I think it would be resonable to assume the collector (10.0.0.1) is misconfigured or something is preventing connections inbound to it.
Ryan Foley
  • 5,479
  • 43
  • You are 100% right with your assumption. I never thought about it because I'm using the example_collector from libipfix (which is supposed to be the reference-implementation). – Christoph Haefner Jan 22 '14 at 09:56
  • I quickly wrote a little programm listening on the 4739-port and just dumping what he gets on screen. Debugging that with Wireshark again brings one important thing up: The Exporter doesn't send a template :/ Might also be the reason why the example collector refuses what he gets ... – Christoph Haefner Jan 22 '14 at 09:59
  • What are you using for flow collection/analyzing? – Ryan Foley Jan 22 '14 at 10:06
  • @Fizzle I'm using http://libipfix.sourceforge.net/ – Christoph Haefner Jan 22 '14 at 10:13
  • What are you using for sFlow collection? I'm convinced your OpenVswitch configurations are correct, but I'm not certain about your collection system. I found an [IETF pdf](http://trac.tools.ietf.org/group/irtf/trac/raw-attachment/wiki/NetworkManagementResearchGroupAg%26LgMunich/nmrg-25-novotny_part_003.pdf) that recommends NfSen (nfdump backend) for flow collection and parsing. Would you be able to try nfdump, instead? I'm not trying to mask the problem, I just can't find a lot of documentation on libipfix. Searching `nfdump setup` nets a significantly larger amount of results. – Ryan Foley Jan 22 '14 at 11:04
    Thanks for your suggestion, I will look into it. I found the mistake by now: The example_collector from libipfix is listening on tcp:4739, while OpenVswitch was sending it out on udp:4739. I didn't see it in wireshark, because I was adding a filter "tcp.port == 4739" ... I was missing the template because it was send once at the very beginning and I stopped wireshark several times and restartet the scan without saving. – Christoph Haefner Jan 22 '14 at 12:12
  • By restarting everything and start plane from scratch I got everything working now. I see the data coming in and wireshark can explain every field of every packet. Thanks to all of you, you earned some good karma for helping a desperate man :) – Christoph Haefner Jan 22 '14 at 12:16
    @ChristophHaefner, thank you for a good question. Please consider asking again if the need arises – Mike Pennington Jan 22 '14 at 12:21
