We are trying to replace our existing router with a newly purchased Cisco router:
GigabitEthernet0/0: PPPoE GigabitEthernet0/1: 192.168.2.1
The PPPoE is getting established perfectly, and I can ping the outside from inside CLI however, the clients cannot ping the outside world. As mentioned, this is replace an existing router with the same IP (ie, 192.168.2.1) therefore, the clients are all setup and working fine when not using the Cisco router.
My configuration is as follows:
    Current configuration : 2698 bytes
version 15.1
service timestamps debug datetime msec
service timestamps log datetime msec
no service password-encryption
hostname r1
boot-start-marker
boot-end-marker
enable secret 4 <secret>
aaa new-model
aaa session-id common
dot11 syslog
ip source-route
ip cef
ip domain name test.com
no ipv6 cef
multilink bundle-name authenticated
voice-card 0
crypto pki token default removal timeout 0
license udi pid CISCO3825 sn FTX1039A0AA
username admin privilege 15 secret 4 <secret>
redundancy
interface GigabitEthernet0/0
 no ip address
 ip nat outside
 ip virtual-reassembly in
 duplex auto
 speed auto
 media-type rj45
 pppoe enable group global
 pppoe-client dial-pool-number 1
 no cdp enable
interface GigabitEthernet0/1
 ip address 192.168.2.1 255.255.255.0
 ip nat inside
 duplex auto
 speed auto
 media-type rj45
interface Dialer0
 ip address negotiated
 no ip redirects
 no ip proxy-arp
 ip mtu 1492
 ip flow ingress
 encapsulation ppp
 ip route-cache policy
 dialer pool 1
 dialer-group 1
 ppp authentication pap callin
 ppp pap sent-username <username> password 0 <password>
 ppp ipcp dns request accept
 ppp ipcp route default
 ppp ipcp address accept
 no cdp enable
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat pool voip-rtp 192.168.2.5 192.168.2.5 netmask 255.255.255.0 type rotary
ip nat inside source list 1 interface GigabitEthernet0/1 overload
ip nat inside source static tcp 192.168.2.10 25 77.71.31.187 25 extendable
ip nat inside source static tcp 192.168.2.5 53 77.71.31.187 53 extendable
ip nat inside source static tcp 192.168.2.15 80 77.71.31.187 80 extendable
ip nat inside source static tcp 192.168.2.15 443 77.71.31.187 443 extendable
ip nat inside source static tcp 192.168.2.10 465 77.71.31.187 465 extendable
ip nat inside source static tcp 192.168.2.10 993 77.71.31.187 993 extendable
ip nat inside source static tcp 192.168.2.10 995 77.71.31.187 995 extendable
ip nat inside source static udp 192.168.2.5 5060 77.71.31.187 5060 extendable
ip nat inside source static udp 192.168.2.20 5080 77.71.31.187 5080 extendable
ip nat inside destination list 114 pool voip-rtp
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0
ip route 64.230.11.5 255.255.255.255 GigabitEthernet0/0
access-list 1 permit 192.168.2.0 0.0.0.255
access-list 114 permit udp any any range 8000 65535
control-plane
mgcp profile default
line con 0
line aux 0
line vty 0 4
 transport input ssh
scheduler allocate 20000 1000
end
Things I tried:
Statically setting the IP route: ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0 ip route 64.230.11.5 255.255.255.255 GigabitEthernet0/0 Although this is probably not needed for auto established PPPoE connection?
Update
IP NAT Trans Output
Pro Inside global         Inside local          Outside local         Outside global
tcp 77.71.31.187:53       192.168.2.5:53        ---                   ---
udp 77.71.31.187:5060     192.168.2.5:5060      <voip supplier's ip>:5060   <voip supplier's ip>:5060
udp 77.71.31.187:5060     192.168.2.5:5060      ---                   ---
tcp 77.71.31.187:25       192.168.2.10:25       217.160.226.122:25    217.160.226.122:25
tcp 77.71.31.187:25       192.168.2.10:25       ---                   ---
tcp 77.71.31.187:465      192.168.2.10:465      ---                   ---
tcp 77.71.31.187:993      192.168.2.10:993      ---                   ---
tcp 77.71.31.187:995      192.168.2.10:995      ---                   ---
tcp 77.71.31.187:80       192.168.2.15:80       66.249.74.2:33795     66.249.74.2:33795
tcp 77.71.31.187:80       192.168.2.15:80       66.249.74.2:50496     66.249.74.2:50496
tcp 77.71.31.187:80       192.168.2.15:80       ---                   ---
tcp 77.71.31.187:443      192.168.2.15:443      ---                   ---
udp 77.71.31.187:5080     192.168.2.20:5080     ---                   ---
Eloy
  • 207
Nick Cameo
  • 431
    How are the clients getting IP addresses? Static or via DHCP (from the existing router)? – Ron Trunk Dec 30 '13 at 19:30
  • Hey Ron! Thank your for your response. I should have mentioned, all addresses are statically defined. This is why I did not implement dhcp on the cisco unit. – Nick Cameo Dec 30 '13 at 19:45
  • Next question: I am assuming there is a switch between the router and the clients. Have you tried clearing the ARP cache on the clients? – Ron Trunk Dec 30 '13 at 19:51
  • Ron, I really appreciate you trying to debug my network. Yes there is a switch, it's a foundry FESX448. Ummm ARP? I will attempt to plug a client directly into the router and see if the results differ. – Nick Cameo Dec 30 '13 at 19:52
  • When the client sends a packet to the default gateway (router), it sends the packet to the router's MAC address. If there is a switch between the client and the router, then the client will think the routers MAC is still the old one. Try clearing the arp cache. On Windows, it's arp -d * – Ron Trunk Dec 30 '13 at 19:57
  • Hello Ron, I attempted to plug directly into the router (no switch), and restarted the network on the linux client (ifdown eth0 followed by ifup eth0) however, WAN pings not getting through. Will try again, this time clearing the ARP cache using "ip -s -s neigh flush all" – Nick Cameo Dec 30 '13 at 20:09
  • OK, so much for the easy stuff ;-) I'm looking at your NAT statements, and I realize I'm not clear what you are trying to accomplish. I believe the inside destination translation only works for TCP, not UDP. Try entering show ip nat translation to see what is going on. – Ron Trunk Dec 30 '13 at 20:29
  • Here is the problem. The statement > ip nat inside source list 1 interface GigabitEthernet0/1 overload is incorrect. You should be specifying the inside global address, i.e. the address that the source will be translated to, which is the outside interface. I'm not sure what happens when you have no IP address on that interface, though. I'd have to test it. But specifying the inside is definitely wrong. Perhaps you should specify the dialer interface – Ron Trunk Dec 30 '13 at 20:54
  • Here's an example: http://www.cisco.com/en/US/docs/routers/access/800/850/software/configuration/guide/pppoenat.html – Ron Trunk Dec 30 '13 at 21:00
  • Hello Ron, cleared the ARP cache on all clients and still no internet access from within the network. I have posted the result of show ip nat trans above. – Nick Cameo Dec 30 '13 at 21:41
  • Regarding RTP, note that NAT supports only standard ACLs, and does not support extended ACLs, you will need a route-map to match the traffic. – aseaudi Dec 31 '13 at 22:07
  • @aseaudi, extended ACLs are supported. Please search the [Cisco NAT FAQ](http://www.cisco.com/en/US/tech/tk648/tk361/technologies_q_and_a_item09186a00800e523b.shtml) for the phrase "access-list extended", and refer to [this Cisco Support Forums thread](https://supportforums.cisco.com/thread/2243921) – Mike Pennington Jan 01 '14 at 11:18
NAT is applied to g0/0, not di0 where it is required. (there's no IP running on g0/0, so none of the IP configuration matters there.)
int di0
 ip nat outside
no ip nat inside source list 1 interface GigabitEthernet0/1 overload
ip nat inside source list 1 interface di0 overload
The two route statements are not necessary. If you need something to trigger the dialer, the route would be ip route 0.0.0.0 0.0.0.0 dialer0, but it should be triggered as long as g0/0 is up/up.
Ricky
  • 31,438
  • 43
  • 84
The NAT statement
is incorrect. You should specify the dialer0 interface instead. Here's a helpful link.
http://www.cisco.com/en/US/docs/routers/access/800/850/software/configuration/guide/pppoenat.html#wp1235296
Ron Trunk
  • 66,852
  • 65
  • 126
  • I will change the statement to `ip nat inside source list 1 interface Dialer0 overload`. Also, is the ip route statement needed? I am hard coding the gateway however, would like it to be determined by dialer0 when the connection is established – Nick Cameo Dec 30 '13 at 21:44
  • Also move the ip nat outside statement to the dialer, as Ricky mentioned. – Ron Trunk Dec 30 '13 at 21:46
  • This all works now. SIP UDP works however, my RTP UDP range is not working. I read this would be an issue. If a 50 dollar dlink can do it why? oh why? – Nick Cameo Dec 30 '13 at 22:15
  • The following is what I have for RTP port forwarding for voip however, to be honest, I am not sure if it is actually correct: `ip nat pool voip-rtp 192.168.2.5 192.168.2.5 netmask 255.255.255.0 type rotary` `ip nat inside destination list 114 pool voip-rtp` `access-list 114 permit udp any any range 8000 65535` – Nick Cameo Dec 30 '13 at 23:43
