When it comes to OSPF and its use of multicast, am I correct in believing that IGMP forwarding and an IGMP querier is still required within the local segment?
My understanding would be without this, the frames would be treated as a broadcast and sent to everyone. Therefore removing the benefit of using multicast.
Based on this is there any mechanism for it to fall back to unicast, to prevent the above. Apologies if my understanding here is way off : )
Ron Maupin
  • 98,218
  • 26
  • 115
  • 191
RickD
  • 269
The benefit of multicast is that hosts not subscribing to the multicast group ignore frames they receive that are sent to the multicast group. With broadcast, they cannot ignore the frames.
The OSPF multicast group is a link-local multicast that gets sent to every switch interface, even with IGMP snooping enabled on the switch. OSPF only uses multicast on broadcast networks, and it is necessary in order to use DR and BDR, which are only on broadcast networks. For point-to-point links, OSPF uses unicast, and for non-broadcast networks you use the neighbor statement and it uses unicast.
OSPF multicast uses the 224.0.0.5 and 224.0.0.6 addresses, which are in the link-local address range. Switches with IGMP snooping are supposed to forward all link-local multicast to every interface, regardless of IGMP snooping. This behavior is defined in RFC 4541, Considerations for Internet Group Management Protocol (IGMP) and Multicast Listener Discovery (MLD) Snooping Switches:
  1. Packets with a destination IP (DIP) address in the 224.0.0.X range which are not IGMP must be forwarded on all ports.
    This recommendation is based on the fact that many host systems do not send Join IP multicast addresses in this range before sending or listening to IP multicast packets. Furthermore, since the 224.0.0.X address range is defined as link-local (not to be routed), it seems unnecessary to keep the state for each address in this range. Additionally, some routers operate in the 224.0.0.X address range without issuing IGMP Joins, and these applications would break if the switch were to prune them due to not having seen a Join Group message from the router.
Ron Maupin
  • 98,218
  • 26
  • 115
  • 191
  • Comments are not for extended discussion; this conversation has been [moved to chat](https://chat.stackexchange.com/rooms/134412/discussion-on-answer-by-ron-maupin-ospf-and-its-use-of-multicast). – Ron Maupin Feb 25 '22 at 03:29
  • when non-ospf interface get ospf information, then how non-ospf understand it's ospf information? And non-ospf this ospf information doesn't share it's other non-ospf interface? – S. M. Feb 25 '22 at 06:13
  • "_when non-ospf interface get ospf information, then how non-ospf understand it's ospf information?_" It does not get OSPF information because OSPF only sends it to OSPF routers in its area. Even connected to an OSPF router in a different area. it will not send OSPOF routing information to it. OSPF sends OSPF hellos, and things must match exactly to start the handshake before data are exchanged. The are multiple thing that must matc, and even if it is two OSPF routers configured for the same area, all the details must match, else they will not become OSPF neighbors that can share information. – Ron Maupin Feb 25 '22 at 14:39
  • when non-ospf router got routing protocol information, it just route the packet into another ospf router? – S. M. Feb 25 '22 at 14:56
  • _**Routing protocols do not route.**_ Routers route packets using their routing table that are independent from the routing protocols. There are three ways routers populate their routing tables, and routing protocols are only one source of routing information. The routing protocol information may or may not be used. The other sources are believed more than the routing protocol information, and multiple routing protocols may be used with a ranking of which is believed over the others. Routers only install the best routes in the routing table. – Ron Maupin Feb 25 '22 at 15:02
  • in ospf area non-ospf router could exists? – S. M. Feb 25 '22 at 15:12
  • A non-OSPF router cannot be part of an OSPF area because it does not speak OSPF. OSPF routers could be physically connected to it, but they cannot use OSPF to share information. Any information from or about the non-OSPF router must be redistributed into OSPF if it is to be shared in the OSPF area, and it will be marked as external information. – Ron Maupin Feb 25 '22 at 15:18
  • redistributed by ospf router who is connected to non-ospf router? – S. M. Feb 25 '22 at 15:57
  • Eac routing protocol has a way to redistribute different routing information into it. For example, a Cisco OSPF router could `redistribute connected`, `redistribute static`, `redistribute eigrp`, etc. to get routing information from other route sources. OSPF can even redistribute from a different OSPF process in the same router. Redistributed information is marked as external by OSPF. – Ron Maupin Feb 25 '22 at 16:08
  • ospf is very vast topic to learn? – S. M. Feb 25 '22 at 16:50
  • It is pretty easy to configure, but if you want to know how it works, it is quite complex. _[RFC 2328, OSPF Version 2](https://www.rfc-editor.org/rfc/rfc2328.html)_ explains how it works for IPv4. – Ron Maupin Feb 25 '22 at 16:54
In terms of what happens to OSPF hello/discovery multicast packets, you're right. The switches send them to everyone on the subnet/VLAN/broadcast domain, as IGMP snooping isn't happening for 224.0.0.0/24, just as Ron explained.
However - and I believe that's the part you didn't consider - a host can still discard these multicast earlier than if they were broadcast. If the host isn't interested in (any/this) multicast group(s), it can drop the ethernet frame (at L2) or the IPv4/IPv6 packet (at L3), without even looking at any inner payload. A broadcast packet however would have to be passed 'further up the stack' to see if it is of interest to any of the running applications/services/deamons.
To add to Ron's list of OSPF's network types/operating modes:
It's good practice to run edge networks connected to OSPF routers with passive interfaces, especially where the OSPF network type is "broadcast" by nature. For example, this is the case in the proverbial "25 client VLANs" of a large campus, each with a few dozen of hosts each at least:
passive-interface
  • keeps the chatter in the campus LAN down
  • reduces exposure of routers to end systems (script-happy CompSci students, anyone?) - no Hellos nor LSAs are exchanged, neither in nor out.
  • saves some ressources on the routers (what with not having to perform the same DR/BDR election with the same peer in dozens of VLANs)
  • still allows the routing information about these networks to be propagated as internal routes to the rest of the OSPF AS. Having them as external routes (by virtue of "redistribute connected") has some implications (desirable or unwanted), e.g. when aggregating, redistributing or filtering routes in other corners of the AS.
Marc 'netztier' Luethi
  • 8,654
  • 30
OSPF's use of multicast is to a link-local scope group, with IP TTL set to 1 to ensure it says link-local. [ 224.0.0.5 and 224.0.0.6 (RFC2328 pp.185-186)]
OSPF aside, for the multicast pruning functions of switches to work, yes, something has to cause group membership reports. All IGMP joins (unsolicited membership report) will eventually expire (RFC 2236 IGMP v2, p.18). If the switch doesn't see periodic reports (ala IGMP snooping of membership reports), that multicast group may be subject to pruning, or flood to all ports. (depending on how your switch is configured)
Ricky
  • 31,438
  • 43
  • 84
