I just need to have a webcam and some equipment on a kite, running on Ethernet. But unfortunately the string will be more than 200 meters long so Ethernet will not work, (as far as I know). Transfer speed should be at least 10mbps. This is scientific project for Antarctic research station.
So what technology do you guys suggest?
Mike Pennington
  • 29,876
  • 78
  • 152
Prostitutor
  • 193
    use fiber optics? – Mike Pennington Nov 22 '13 at 19:03
  • If fiber could take the stress -- I hear it's damned cold down there. I was thinking LRE (long reach ethernet), or some sort of DSL bridge. Until you said "Antarctic", I was thinking WiFi, but that might not work so well in dense snow. – Ricky Nov 22 '13 at 20:49
  • @RickyBeam, that depends on [what you buy](http://www.aflglobal.com/Products/Fiber-Optic-Cable/Loose-Tube/LA-Series-Arctic-Low-Temperature-Loose-Tube-Cable.aspx "Low temperature fiber optic cable") – Mike Pennington Nov 22 '13 at 21:50
  • @Mike, if his kite can lug 100+lbs of cable into the air, plus the instrumentation, and it stays above -50C. – Ricky Nov 23 '13 at 00:02
  • Maybe a silly question, but why not just store the data inboard the kite and retrieve it later. SSDs are dirt cheap and lighter than almost any solution we'd propose. Also why a kite? Most arial survey/research I've seen uses balloons, which I would believe have a much higher load capacity. – Brett Lykins Nov 23 '13 at 13:32
  • How about just sending the power up via cables, and sending down the data via wifi? – Daniel F Dec 01 '13 at 11:15
  • Maybe something along these lines could provide useful http://routerboard.com/RB911G-2HPnD – Daniel F Dec 01 '13 at 11:41
Something like this:
http://www.veracityglobal.com/products/ethernet-and-poe-extension/outreach-lite.aspx
There are many other devices that will use PoE as a power source (and still forward voltage) and can act as a passive repeater. I would only recommend it as a temporary solution though.
Depending on the weight your kite can support it may be a better idea to go with a P2P wireless bridge. You can achieve really good signal quality with homemade wireless antennas at distances up to 2 miles with simple pringles can builds.
see also:
http://www.wikihow.com/Build-a-Low-Cost-WiFi-Antenna http://wireless.gumph.org/articles/homemadeomni.html
http://en.wikipedia.org/wiki/Cantenna
http://www.makeuseof.com/tag/how-to-make-a-wifi-antenna-out-of-a-pringles-can-nb/
John Kennedy
  • 1,071
  • ...I wonder if he could jury-rig a small switch/battery package to hang on the kite guy wire. If it was light enough, you could stretch the ethernet out multiple hops that way. (oh, what a hack. :) – Craig Constantine Nov 22 '13 at 18:21
