I have a question to the following excercise that I have from school.
How big is the delay of a package if it gets send via satelite (~35km above earth)?
I assume I need to calculate this one. However I have no other values so I don't really know if this really can be calculated?
Prc
  • Unfortunately, questions or help about homework, examinations or certifications are off-topic here. –  Jan 06 '18 at 15:43
  • Here's also a good read: [https://networkengineering.stackexchange.com/questions/46422/is-there-a-difference-between-latency-and-speed](https://networkengineering.stackexchange.com/questions/46422/is-there-a-difference-between-latency-and-speed) –  Jan 06 '18 at 16:12
What you need is the distance to be covered and the speed of the signal.
The distance of an arbitrary point on the globe to a point above the equator can be calculated by the cosine rule. The speed of the signal - well, you've probably got that.
btw: geostationary orbit is 35,786 km above the equator, so it's more like ~36,000 km. 35 km is well within the atmosphere, much too low for a satellite (about 50% higher than the normal flight altitude of an SR-71 and somewhat below Baumgartner's and Eustace's stratosphere 'space' dives).
Zac67
  • 81,287
  • 67
  • 131
