I would like to have syntax highlighting while perusing my configs - does anybody know of a good Cisco IOS syntax highlighting bundle for TextMate or Sublime Text?
Edited (2015-09-21) to add:
GitHub Atom Editor has a Cisco IOS syntax highlighter in their built in "packages" repo and it is easy to install. I think that Sublime Text is a better editor, but if you are not already invested in ST, I recommend giving Atom a look.
Jan
  • 623
I haven't tried it yet but there is a GitHub repo someone made for Cisco IOS Syntax Highlighting for Sublime Text 2.
bigbash
  • 666
Though a .tmBundle exists for syntax highlighting in Cisco IOS, it is very limited in scope.
Have you made or do you know of a better bundle?
Jan
  • 623
  • Are you referring to this one, or something else? http://polydistortion.net/monkey/archives/2006/06/24/003722.html – lunistorvalds May 16 '13 at 13:46
  • @routelastresort Yes, I've linked it but it might be hard to see that `.tmBundle` is a link in my post :) – Jan May 16 '13 at 13:54
    You should merge the info in this answer into your original question. – Craig Constantine May 16 '13 at 14:14
  • >[To be crystal clear, **it is not merely OK to ask and answer your own question, it is _explicitly encouraged_.**](http://http://blog.stackoverflow.com/2011/07/its-ok-to-ask-and-answer-your-own-questions/) – Jan May 16 '13 at 18:16
Grab Notepad++ which has many different language (formatting=parsing) options. Though I don't have a specific one for Cisco, I'm sure someone's created one or you can define your own.
generalnetworkerror
  • 7,094
  • 32
  • 65
You can try Network Tech if you use Sublime Text 3. I am the author.
