4 routers, lab environment. Trying to filter out routes originating from AS2 (not that leverage AS2 as transit). The process I've followed is:
Bakers#sh ip bgp regex _2_
BGP table version is 41, local router ID is 33.33.33.33
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
r RIB-failure, S Stale
Origin codes: i - IGP, e - EGP, ? - incomplete
Network Next Hop Metric LocPrf Weight Path
*> 2.2.2.0/24 192.168.23.2 0 0 2 i
* 4.4.4.0/24 192.168.23.2 0 2 1 i
*> 22.22.22.0/24 192.168.23.2 0 0 2 i
* 44.44.44.0/24 192.168.23.2 0 2 1 i
*> 192.168.12.0 192.168.23.2 0 0 2 i
* 192.168.14.0 192.168.23.2 0 2 1 i
* 192.168.23.0 192.168.23.2 0 0 2 i
Bakers#sh ip bgp regex _2$
At this point, I'm thinking, OK - have what I need to make an as-path ACL to filter out the stuff originating from AS2 since the regex searching checks out per the above. I create and apply the following:
Bakers#sh run | i as-path
ip as-path access-list 10 deny _2$
ip as-path access-list 10 permit .*
router bgp 3
no synchronization
bgp log-neighbor-changes
<truncated>
neighbor 192.168.23.2 remote-as 2
neighbor 192.168.34.4 remote-as 4
neighbor 192.168.34.4 filter-list 10 out
no auto-summary
I would then expect the advertised routes to mimic the 'sh ip bgp regex 2' output from earlier (giving me the desired result), sans the routes output with the 'sh ip bgp regex _2$' routes. Unfortunately, I get this:
Bakers#sh ip bgp neigh 192.168.34.4 advertised-routes
*> 3.3.3.0/24 0.0.0.0 0 32768 i
*> 33.33.33.0/24 0.0.0.0 0 32768 i
*> 192.168.23.0 0.0.0.0 0 32768 i
*> 192.168.34.0 0.0.0.0 0 32768 i
It's filtering out all of the routes originating from AS1 (meaning that downstream, that router can no longer use AS3 as transit to AS1 - breaking my use case). What am I missing here?
