I was a little confused between packet and frame. The confusion was based on, if a switch is a layer 2 device, how does it reads a packet from a layer 3 device, and where is the 'frame' thing which is understandable to a switch (or layer 2 device)?
From all the blogs and articles I read, I came to conclusion that when a host send out a packet to a switch, it only reads it up to the data link layer, and the process of putting that packet from ingress to egress port is where the frame terminology is used.
I am sorry if I haven't communicated my question thoroughly, but this is kind of messed up for me.
Ron Maupin
  • 98,218
  • 26
  • 115
  • 191
Taha
  • 83
You need to understand the concept of layers.
An application will send data to the Transport Layer. The Transport Layer protocol will encapsulate the data inside headers for the Transport Layer protocol, and pass those to the Network Layer.
The Network Layer will encapsulate the datagrams it receives inside Network Layer headers, and those are called packets. The packets will be passed to the Data-Link Layer.
The Data-Link Layer will encapsulate the packets inside Data-Link Layer headers, and those are called frames.
Switches only look at the frames, and not at the packets. Routers strip off and discard the frame headers, and they only look at the packets.
For example:
An application on Host A sends data to an application on Host B, via TCP. The application on Host A will send the data to TCP, and TCP segments the data into TCP segments, each of which have a TCP header that includes the source and destination TCP addresses (ports).
TCP passes the segments to IP. IP will add the IP headers, creating IP packets, each of which contain the source and destination IP addresses.
IP passes the packets to ethernet. Ethernet will add the ethernet headers, creating ethernet frames, each of which will have the source and destination ethernet addresses (MAC addresses).
Ethernet will send the frames on the wire to an ethernet switch. The switch will inspect the frame headers, and it will switch the frames to the interface where it last saw the destination MAC address. If it doesn't have a destination interface, it will flood the frames to all interfaces except the one where it received the frame.
The switch doesn't know or care what Network Layer protocol is used because it knows nothing about Network Layer protocols.
When the destination host receives the frame, it reverses the process used to encapsulate the data, and the data end up in the destination application.
Ron Maupin
  • 98,218
  • 26
  • 115
  • 191
  • This totally makes sense to me. Thanks for spending time over it. – Taha Feb 12 '17 at 19:22
    Would it be correct to assume if the data is unencrypted, then in theory a rogue switch could be programmed to violate layer encapsulation, inspect packet contents and route accordingly? I.e. preferred content prioritization through an ISP. – Darren Ringer Feb 12 '17 at 23:00
    @DarrenRinger That's called [Deep Packet Inspection](https://en.wikipedia.org/wiki/Deep_packet_inspection); and tools for doing so are readily available commercially for both benign and malign usages. – Dan Is Fiddling By Firelight Feb 12 '17 at 23:10
    @DarrenRinger adding on Dan's answer - the switch is a device that can do a lot of things, including many actions based on deeper protocols. The point is that switching - the main task of switch - is (can be) done irrelevant of other layers and thus the switch can be swapped, reconfigured regardless of other layers. – Džuris Feb 12 '17 at 23:31
  • @DarrenRinger maybe check out the possibilites of a [small business switch](http://www.cisco.com/c/en/us/products/collateral/switches/small-business-smart-switches/data_sheet_c78-610061.html). For example, it can prioritize telephony over other uses. – Džuris Feb 12 '17 at 23:35
  • It helps to imagine switches for cases where the correspondence between packets and frames isn't 1-to-1. For example, an ATM switch, where frames have a fixed size that is smaller than most packets. – David Schwartz Aug 25 '17 at 17:58
As Ron pointed out the switch encapsulates the data from the router. You can use this for your reference:
information generated at the application layer (for instance this web browser) is called data.
the transport layer encapsulates it and calls segment
At network layer it is a called a packet
A frame at the data link layer
and at the physical layer they are just bits transmitted through various mechanisms.
john
  • 1,237
If it's a layer3 switch with IP routing enabled, it's effectively a router. Regarding a switch, it processes frames. That's it.
Ronnie Royston
  • 4,379
