I pulled an old ASA5550 off the shelf, which had 8.4(2) loaded on it. When I tried to boot it, I got the following error...
Traceback output aborted.
Flushing first exception frame:
Abort: Assert failure
vector 0x00000000
edi 0x00000002
esi 0x0973a2dc
ebp 0x09fceef8
esp 0x09fceeec
ebx 0x00000187
edx 0x09fcef30
ecx 0x00000006
eax 0x00000000
error code n/a
eip 0xdd6a62a1
cs 0x00000073
eflags 0x00003246
CR2 0x00000000
Nested traceback attempted via signal, from:
vector 0x00000000
edi 0x09fce92c
esi 0x09fce9cc
ebp 0x09fce7f8
esp 0x09fce7ec
ebx 0x00000187
edx 0x09fce834
ecx 0x00000006
eax 0x00000000
error code n/a
eip 0xdd6a62a1
cs 0x00000073
eflags 0x00003203
CR2 0x00000000
An internal error occurred. Specifically, a programming assertion was
violated. Copy the error message exactly as it appears, and get the
output of the show version command and the contents of the configuration
file. Then call your technical support representative.
assertion "_vf_mode_init" failed: file "vf_api.c", line 99
What is the problem when you get assertion "_vf_mode_init" failed: file "vf_api.c", line 99
Google searches turn up a lot of GNS3 discussion, and this Cisco Support Forums Case, but nothing gets to the root cause of the issue AFAICT.
