I saw this example online .
192.168.12.0/23 applies the network mask 255.255.254.0 to the 192.168 network, starting at 192.168.12.0. This notation represents the address range 192.168.12.0 - 192.168.13.255.
How do I obtain the applicable address range ?
Here's my understanding (most likely flawed) of the 192.168.12.0/23 CIDR IP address :
  1. /23 written in bits is 11111111.11111111.11111110.00000000 .
  2. Therefore, it "borrowed" 7 bits from the host field.
  3. 2^7 = 128 subnets being created.
  4. 2^1 = Each subnet has a maximum of 2 hosts.
  5. There are 128 possible network IDs, possible ones are 192.168.0.0, 192.168.170.0 192.168.254.0.
  6. The range of ip addresses are from 192.168.0.0 to 192.168.254.0 ?
Mike Pennington
  • 29,876
  • 78
  • 152
iridescent
  • 237
Address:   192.168.12.0         11000000.10101000.0000110 0.00000000
Netmask:   255.255.254.0 = 23   11111111.11111111.1111111 0.00000000
Network:   192.168.12.0/23      11000000.10101000.0000110 0.00000000
HostMin:   192.168.12.1         11000000.10101000.0000110 0.00000001
HostMax:   192.168.13.254       11000000.10101000.0000110 1.11111110
Broadcast: 192.168.13.255       11000000.10101000.0000110 1.11111111
Hosts/Net: 510                   Class C, Private Internet
Here you go. First you take the network id (192.168.12.0), and the mask (23) says the first 23 bits are static, and the remaining 9 bits are used in your network.
So in your case:
First 23 bits are to here^
Remaining 9 bits go from all zeros to all ones
If you write the IP back to decimal form, you get IPs from 192.168.12.0 (last 9 bits are zeros), to 192.168.13.255 (last 9 bits are all ones). First 23 bits are unchanged.
Since 9 bits are used for host IPs, thats 2^9 = 512 IPs (minus one for network ID and minus one for the broadcast address = 510 usable IPs).
mulaz
  • 1,924
    http://jodies.de/ipcalc <- tool used for calculation/pretty-print - also in most linux distro repositories – mulaz Oct 07 '13 at 14:25
the 1 bits in the address are the network part of the address, this cannot be used for assigning hosts.
In this example, you can use 9 bits for the hosts (minus 2 hosts, reserved for the broadcast and network address).In the /23 you have, you can use:
  • 11000000.10101000.0000110 | 0.00000000 = 192.168.12.0
  • 11000000.10101000.0000110 | 1.11111111 = 192.168.13.255
  • 11111111.11111111.1111111 | 0.00000000 = 255.255.254.0
everything before the "|" is the network area, that cannot be changed in this subnet. Everything after, you can use for your hosts, except the all-0's and all-1's. This is clear if you put the subnetmask under it.
You can calculate everything here (and on other sites): http://www.adminsub.net/ipv4-subnet-calculator/192.168.12.0/23
Bulki
  • 2,363
  • 43
  • Great link as well, thanks :) . Hmm for CIDR, there isn't such a thing as number of subnets created right ? Number of subnets created only applies for the traditional subnetting based on classes(A/B/C) ? – iridescent Oct 07 '13 at 15:56
  • Network calculators are handy things - it's easy to mess up when getting away from the "standard" numeric ranges. Running a /18 and a /22 here. – Ecnerwal Oct 07 '13 at 20:26
    @Ecnerwal yeah idd, I always keep a cheatsheet laying around. Just to be quicker. (http://packetlife.net/media/library/15/IPv4_Subnetting.pdf) – Bulki Oct 08 '13 at 05:25
