A small ISP I provide service for has recently been consolidating their equipment. One of their small branches only has a handful (5 or so) of users receiving their internet through a router, a Cisco 3725, using PPP with a RADIUS server for AAA, and a VirtualAccess template.
Instead of keeping a server dedicated to providing RADIUS, I would like to retire it, and put usernames, passwords, and any other rules in the router's configuration. I've done this in a testing environment, and notice that it works, with one major difference:
  • In the original RADIUS setup, a completely new VirtualAccess (Vi1, Vi2, Vi3, etc) interface was created with each user.
  • In the local setup, a sub-interface of VirtualAccess1 (Vi1.1, Vi1.2, Vi1.3) is created for each user.
Is their any way to create a separate VirtualAccess interface for each user, but keep the authentication local?
Much of the configuration has been copied from our production environment, and such is heavily edited here:
version 12.3
service timestamps debug datetime year
service timestamps log datetime year
service password-encryption
hostname [removed]
boot-start-marker
boot-end-marker
logging buffered 131072 debugging
logging console alerts
enable password [removed]
aaa new-model
aaa session-mib disconnect
aaa authentication ppp default none
aaa authentication ppp [isp]-auth local
aaa authorization network [isp]-auth local
aaa accounting delay-start
aaa accounting update periodic 1
aaa attribute list [username 1 removed]
 attribute type addr [ip 1 removed]
aaa attribute list [username 2 removed]
 attribute type addr [ip 2 removed]
aaa attribute list [username 3 removed]
 attribute type addr [ip 3 removed]
aaa session-id common
resource policy
no ip subnet-zero
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.255.254.1 10.255.254.50
ip dhcp excluded-address 10.255.252.1 10.255.252.50
ip dhcp pool [isp]-wasteland1
   network 10.255.254.0 255.255.254.0
   domain-name [isp].com
   dns-server 4.2.2.2 8.2.2.2
   default-router 10.255.254.1
ip dhcp pool [isp]-wasteland2
   network 10.255.252.0 255.255.254.0
   default-router 10.255.252.1
ip domain name [removed]
ip name-server 4.2.2.2
virtual-profile if-needed
virtual-profile virtual-template 11
no ftp-server write-enable
async-bootp dns-server 4.2.2.2 8.2.2.2
username [username] password [password]
... (5 more)
class-map match-all default-class
 match any
[removed policy maps]
crypto isakmp ccm
bba-group pppoe global
 virtual-template 11
interface Loopback0
 no ip address
interface FastEthernet0/0
 description [removed]
 ip address [ip address] [subnet] secondary
 duplex auto
 speed auto
 service-policy input [removed]
 service-policy output [removed]
interface Serial0/0
 no ip address
 shutdown
interface FastEthernet0/1
 no ip address
 speed 100
 full-duplex
interface FastEthernet0/1.217
 encapsulation dot1Q 217
 pppoe enable group global
interface FastEthernet0/1.218
 encapsulation dot1Q 218
interface FastEthernet0/1.219
 encapsulation dot1Q 219
interface FastEthernet0/1.220
 description ** UNUSED **
 encapsulation dot1Q 220
 shutdown
interface FastEthernet0/1.221
 encapsulation dot1Q 221
 shutdown
interface Virtual-Template11
 description PPPoE user
 ip unnumbered FastEthernet0/0
 peer default ip address pool [pool-name]
 ppp authentication pap [isp]-auth
 ppp authorization [isp]-auth
 ppp accounting [isp]-auth
 service-policy [removed]
ip local pool [pool-name] [xxx.xxx.xxx].130 [xxx.xxx.xxx].189
ip local pool [pool-name] [xxx.xxx.xxx].64 [xxx.xxx.xxx].126
no ip classless
ip route 0.0.0.0 0.0.0.0 [gateway]
ip http server
no ip http secure-server
logging trap debugging
logging facility local4
logging [logging ip]
access-list 101 permit ip any any
snmp-server community [isp]-public RO
snmp-server community [isp]-read-write RW
control-plane
line con 0
line aux 0
line vty 0 4
 privilege level 2
 [password removed]
 transport input telnet ssh
ntp clock-period 17180651
ntp server 204.2.134.164
ntp server 204.2.134.163
ntp server 77.66.37.130
end
Ron Maupin
  • 98,218
  • 26
  • 115
  • 191
renwique
  • 71
0 Answers0
