We have a simple problem. We want to restrict our wireless users to certain business websites based on their username when they login. We have many kinds of wireless devices: voip phones, cell phone, laptops, barcode scanners, and tablets.
Suppose there are all these website categories, which we have an SSID and Vlan assigned for user source addresses:
  • Internet (SSID-Internet, Vlan101)
  • Voice (SSID-Internet, Vlan102)
  • Accounting (SSID-Business, Vlan103)
  • HR (SSID-Business, Vlan104)
  • Inventory (SSID-Business, Vlan105)
  • Research (SSID-Business, Vlan106)
  • Quality Assurance (SSID-Business, Vlan107)
  • Manufacturing (SSID-Business, Vlan108)
Each of our users might need to use their Windows login to authenticate into the wireless network, but they should only have access to certain services. Some examples:
  • User1: Login using Windows credentials using VoIP phone to SSID-Voice, and can only access the Voice network from this phone
  • User1: Login using Windows credentials using Laptop to SSID-Business, and can only access the Accounting websites from his laptop
  • User1: Login using Windows credentials using cell phone to SSID-Internet and can only access the internet through a proxy.
  • User2: Login using Windows credentials using VoIP phone to SSID-Voice, and can only access the Voice network from his phone
  • User2: Login using Windows credentials using barcode scanner to SSID-Business and can only access the Inventory websites from his barcode scanner
  • User2: Login using Windows credentials using cell phone to SSID-Internet and can only access the internet through a proxy.
Every user should be able to login with their cell phone to SSID-Internet, and wifi phone to SSID-Voice. This seems easy enough if we use mac-address filtering. We will use a firewall to ensure users in the Vlans don't go outside their access limits.
The problem is that we don't want to create a lot of SSIDs, so the number of different Vlans for SSID-Business is hard. We want to assign users to several different Vlans when they login to SSID-Business. Can Cisco ISE & Cisco ACS do this? If so, what features do we need to use in Cisco ISE, Cisco ACS and the WLC? Can all these functions work if we only have one Windows username per user?
Our WLC is a 5508 running 7.4. We have Cisco ACS 5 and Cisco ISE 1.2.
user2631
  • 81
  • Did any answer help you? if so, you should accept the answer so that the question doesn't keep popping up forever, looking for an answer. Alternatively, you could post and accept your own answer. – Ron Maupin Jan 03 '21 at 19:41
If you don't need to confuse your users with multiple VLANs, don't do it. Leverage the tools you have. You mentioned you have ISE and you should be able to do all this with one SSID. As AdnanG already mentioned, you can utilize the profiling features of ISE to classify the devices.
Your ACS should be able to tie into the MS AD authentication and be able to provide user authentication and group information.
From there, you just need to combine the user/groups with the device profiles and then tie it to a VLAN. So, for instance, if the device is identified as a cell phone and the user is part of "group A", then the get put in the "group A - internet" VLAN.
I haven't done it personally with ISE, so can't give exact steps, but this is how Cisco marketing is selling ISE in the BYOD space. I also know of several people who have done similar setups to what is suggested. I would start by looking through this Cisco BYOD document that would give you a general overview of how BYOD is done with with Cisco ISE.
YLearn
  • 27,141
  • 59
  • 128
Cisco Identitiy SErvices Engine (ISE) can do exactly what you are looking for. The feature is called "Profiling" your netowrk devices. Cisco ACS will be used for Authentication and Integration with your Active Directory. Please note that in order to achieve what you are looking for, you might need a range of devices in the structure of your netowrk. This link has an overview of the solution that will give you better understanding of what you need. Refer to 'Deployment Components' section for an idea of what it takes to have profiling. The solution might sound complicated but it all depends on your deployment. If would be wrong to buy a couple of devices thinking that it will suffice to give you the functionality you are looking for. Cisco's solutions usually involve many components and must be carefully planned.
AdnanG
  • 353
A solution would be applying 802.11x on the wireless access points (RADIUS) and integrating the authentication for this via LDAP with windows, then only users that have a windows username and password can access the APs.
The benefit of this is that windows server can then control what can be accessed based on the user's login details using group policy, security permissions in Active Directory etc.
But this solution is 2 tiered, the windows guys need to understand how this is going to work and the network side has to be setup as well.
The previous poster also mentioned Cisco Identity Services Engine (ISE) which would also work. It really depends on your setup
