I think it is a similar case like this one. The only problem is that here I have a dynamic IP from the ISP, which gets updated from dhcp.
The asa can ping outside, however the inside hosts on vlan1 cannot ping internet IP addresses (eg. google).
This is my config:
ASA Version 9.2(3)4
hostname myname
enable password aaa encrypted
passwd aaaa encrypted
names
interface Ethernet0/0
 switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
 nameif inside
 security-level 100
 ip address 192.168.1.2 255.255.255.0
interface Vlan2
 nameif outside
 security-level 0
 ip address dhcp setroute
boot system disk0:/asa923-4-k8.bin
ftp mode passive
clock timezone CET 1
clock summer-time CET recurring last Sun Mar 2:00 last Sun Oct 3:00
object network obj_any
 subnet 0.0.0.0 0.0.0.0
pager lines 24
logging asdm informational
mtu inside 1500
mtu outside 1500
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-741.bin
no asdm history enable
arp timeout 14400
no arp permit-nonconnected
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
aaa authentication ssh console LOCAL
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
crypto ipsec security-association pmtu-aging infinite
crypto ca trustpoint _SmartCallHome_ServerCA
 no validation-usage
 crl configure
crypto ca trustpoint ASDM_Launcher_Access_TrustPoint_0
 enrollment self
 fqdn none
 subject-name CN=192.168.1.26,CN=sergioasa
 keypair ASDM_LAUNCHER
 crl configure
crypto ca trustpool policy
crypto ca certificate chain _SmartCallHome_ServerCA
 certificate ca ***cert stuff***
  quit
crypto ca certificate chain ASDM_Launcher_Access_TrustPoint_0
 certificate ***cert stuff***
  quit
telnet timeout 5
ssh stricthostkeycheck
ssh 0.0.0.0 0.0.0.0 inside
ssh timeout 5
ssh version 2
ssh key-exchange group dh-group1-sha1
console timeout 0
dhcpd auto_config outside
dhcprelay server 192.168.1.1 outside
dhcprelay enable inside
dhcprelay setroute inside
dhcprelay timeout 60
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
ssl trust-point ASDM_Launcher_Access_TrustPoint_0
username sergio password aaaa encrypted
prompt hostname context
call-home reporting anonymous
Cryptochecksum:chesumnumbers
I think probably a route is missing... but how to add a route that sends all the outside traffic to vlan2 instead than to a precise IP address?
After adding:
 nat (inside,outside) dynamic interface
I run:
packet-tracer input inside tcp 192.168.1.100 323 8.8.8.8 80 detailed
And I got:
Phase: 1
Type: ROUTE-LOOKUP
Subtype: Resolve Egress Interface
Result: ALLOW
Config:
Additional Information:
in   0.0.0.0         0.0.0.0         via 192.168.0.1, outside
Phase: 2
Type: NAT
Subtype:
Result: ALLOW
Config:
Dynamic translate 192.168.1.100/323 to 192.168.0.12/323
 Forward Flow based lookup yields rule:
 in  id=0xcd238b10, priority=6, domain=nat, deny=false
        hits=1, user_data=0xcd02f3c0, cs_id=0x0, flags=0x0, protocol=0
        src ip/id=0.0.0.0, mask=0.0.0.0, port=0, tag=0
        dst ip/id=0.0.0.0, mask=0.0.0.0, port=0, tag=0, dscp=0x0
        input_ifc=inside, output_ifc=outside
Phase: 3
Type: NAT
Subtype: per-session
Result: ALLOW
Config:
 in  id=0xcc34e8e8, priority=0, domain=nat-per-session, deny=false
        hits=810, user_data=0x0, cs_id=0x0, reverse, use_real_addr, flags=0x0, protocol=6
        input_ifc=any, output_ifc=any
Phase: 4
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
 in  id=0xcc9bf968, priority=0, domain=inspect-ip-options, deny=true
        hits=1341, user_data=0x0, cs_id=0x0, reverse, flags=0x0, protocol=0
        input_ifc=inside, output_ifc=any
Phase: 5
Type: NAT
Result: ALLOW
Config:
 Reverse Flow based lookup yields rule:
        hits=812, user_data=0x0, cs_id=0x0, reverse, use_real_addr, flags=0x0, protocol=6
Phase: 6
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
 in  id=0xcc9d68d0, priority=0, domain=inspect-ip-options, deny=true
        hits=1075, user_data=0x0, cs_id=0x0, reverse, flags=0x0, protocol=0
        input_ifc=outside, output_ifc=any
Phase: 7
Type: FLOW-CREATION
Subtype:
Result: ALLOW
Config:
New flow created with id 1249, packet dispatched to next module
Module information for forward flow ...
snp_fp_tracer_drop
snp_fp_inspect_ip_options
snp_fp_tcp_normalizer
snp_fp_translate
snp_fp_adjacency
snp_fp_fragment
snp_ifc_stat
Module information for reverse flow ...
snp_fp_tracer_drop
snp_fp_translate
snp_fp_adjacency
snp_fp_fragment
snp_ifc_stat
Result:
input-interface: inside
input-status: up
input-line-status: up
output-interface: outside
output-status: up
output-line-status: up
Action: allow
On the ISR(dhcp server) I have the following routing table:
Gateway of last resort is not set
     10.0.0.0/24 is subnetted, 1 subnets
C       10.11.0.0 is directly connected, Loopback0
C    192.168.1.0/24 is directly connected, BVI1
On the ASA the routing table is:
Gateway of last resort is 192.168.0.1 to network 0.0.0.0
S*    0.0.0.0 0.0.0.0 [1/0] via 192.168.0.1, outside
C        192.168.0.0 255.255.255.0 is directly connected, outside
L        192.168.0.12 255.255.255.255 is directly connected, outside
C        192.168.1.0 255.255.255.0 is directly connected, inside
L        192.168.1.2 255.255.255.255 is directly connected, inside
Pikk
  • 151
If the ASA can ping the internet then routing on the firewall is fine.
Although I did noticed I can't see a NAT statement to nat your traffic from your inside to the outside address
Apply the NAT under your object.
If this doesn't resolve your issue please post the output from the following command
Smithy2k3
  • 311
  • still didn't work. I added the info on the question – Pikk Apr 17 '15 at 17:24
  • Ah the outside address isn't a IPv4 Public address. possibly why you didn't need to NAT but from the config it was hard to see. As you can see from the packet-tracer its looking up the next-hop route fine and sending it to 192.168.0.1 is this the correct next-hop?. Is the next-hop your ISP router? I assume he's configured to NAT your traffic appropriately if so? – Smithy2k3 Apr 17 '15 at 17:51
  • On ethernet 0/0 there is attached a cable modem that gives private class IPv4 addresses... but it's an address on another network. Now it receives 192.168.0.12, the inside hosts have 192.168.1.x – Pikk Apr 17 '15 at 17:53
  • Ok but we know for sure the firewall is allowing the traffic through i suppose you need to confirm the next-hop is correct? Im guessing the NAT may still be required so your cable modem knows where to send traffic back to (i.e the firewall) unless it has a static route back to your ASA – Smithy2k3 Apr 17 '15 at 17:56
  • The next hop is working fine by default. If I connect clients directly to the cable modem they receive 192.168.0.x IP and can surf the net. If I attach to that cable modem other routers, such as linksys or Cisco ISR, they also work fine... and that ISR doesn't have any NAT or ROUTE in the config. I am wondering that there could be an issue with the DHCP server config... now that ISR is attached to the ASA and servers as DHCP server, and the hosts on the ASA are getting the IP from that DHCP server. They receive 192.168.1.1 as default gateway. Maybe it's wrong – Pikk Apr 17 '15 at 18:02
  • Well the ASA is 192.168.1.2 - So what is the routing table showing on 192.168.1.1? If the 192.168.1.1 is simply the DHCP server then yes he should hand out 192.168.1.2 as the default gateway. Try set it statically on a PC – Smithy2k3 Apr 17 '15 at 18:25
  • Thanks, on the ISR I set 192.168.1.2 as default gateway. Now the clients connected to the ASA are able to surf the internet :D But for some strange reason from the hosts I cannot ping anything in the internet. DNS resolves well, but Request timed out. Just added the routing tables of ISR and ASA to the top post. – Pikk Apr 17 '15 at 18:28
  • Sorry whats different between "clients" and "hosts"? Are these on the same network etc? – Smithy2k3 Apr 17 '15 at 18:34
  • Sorry the same, two words for the same thing. I mean the computers connected to the ASA via cable. If you prefer we can mark it as resolved (because even if it's not working 100% correctly) it's now working and the computers can now connect to the internet. And I can open a new question to troubleshoot the ping problem. – Pikk Apr 17 '15 at 18:35
  • Its probably because you have no ICMP fixup. – Smithy2k3 Apr 17 '15 at 18:42
  • do you know how to fix it? – Pikk Apr 17 '15 at 18:44
  • posted another answer because I couldn't do the formatting on this – Smithy2k3 Apr 17 '15 at 18:45
To fix ICMP try this
       class-map inspection_default
        match default-inspection-traffic
       policy-map global_policy
        class inspection_default
         inspect icmp
       service-policy global_policy global
Smithy2k3
  • 311
