13
I don't quite understand if i posting http form data from the browser to the server, does the protocol still need to make three-way handshake (syn-ack-data) or it only works for GET http requests?
Ron Maupin
  • 98,218
  • 26
  • 115
  • 191
If you are asking in a general sense, then the answer is most definitely "yes", any HTTP method (like POST) requires a TCP connection, and the only way to initiate a TCP connection is to use the three way handshake.
IF, however, you are asking in a specific case, maybe if you are capturing your own traffic and don't see the 3 way handshake after you submit content to a website, then the answer is a little less simple. We'll have to discuss a few HTTP related concepts before we can properly answer it...
In the original release of HTTP1.0, every object you requested from a webpage required a new TCP connection to be formed for each object. Take the following simplistic website that includes some text, and two images:
<HTML>
  <HEAD>
    <TITLE>My Title</TITLE>
  </HEAD>
  <BODY>
    Stack Exchange Rules!
    <IMG SRC="a.gif">
    <IMG SRC="b.gif">
  </BODY>
</HTML>
In traditional HTTP1.0, to load this website into your browser would require three TCP connections (each with their own 3-way handshake, and 4-way closure).
HTTP 1.0:
--> SYN
                SYN ACK <--
--> ACK
--> GET /index.html
           <index.html> <--
--> FIN
                    ACK <--
                    FIN <--
--> ACK
--> SYN
                SYN ACK <--
--> ACK
--> GET /a.gif
                <a.gif> <--
--> FIN
                    ACK <--
                    FIN <--
--> ACK
--> SYN
                SYN ACK <--
--> ACK
--> GET /b.gif
                <b.gif> <--
--> FIN
                    ACK <--
                    FIN <--
--> ACK
Note there are 27 packets above, just to download three items: The HTML page itself (index.html), image a.gif, and image b.gif. (there would actually be more than 27 packets, but to save vertical space, I only included the ACK's in the 3-way-handshake and the 4-way-closure, and omitted ACK's within the data stream)
To improve the efficiency of HTTP, a feature called "Connection Keepalive" was introduced, which allows HTTP to re-use the same TCP connection to request for multiple objects. The transfer above would be reduced to the following:
HTTP 1.1 with Connection Keepalive
--> SYN
                SYN ACK <--
--> ACK
--> GET /index.html
           <index.html> <--
--> GET /a.gif
                <a.gif> <--
--> GET /b.gif
                <b.gif> <--
--> FIN
                    ACK <--
                    FIN <--
--> ACK
Notice that only a single TCP connection was used to request all three objects. This time, it only took 13 packets, a large improvement from the 27 from earlier.
The last imrpovement to HTTP that we must discuss is a feature called Pipelining. This feature further increased HTTP's efficiency, by making it so the Client can requests multiple options at once, without waiting to receive the prior asked object. Let me show you:
HTTP1.1 with Pipelining
--> SYN
                SYN ACK <--
--> ACK
--> GET /index.html
--> GET /a.gif
--> GET /b.gif
           <index.html> <--
                <a.gif> <--
                <b.gif> <--
--> FIN
                    ACK <--
                    FIN <--
--> ACK
We're still only using one TCP connection, and we're still only using 9 packets. However, we don't have to wait the Round Trip Time (RTT) it takes between the Client and the Server in between asking for and receiving each object. If you need an analogy, imagine you're at a Restaurant, and you need Salt, Pepper, and Ketchup. Is it more efficient to ask your waiter/waitress for all three items at once, or to ask for them one at a time and wait for them to come back before making the next request?
(Pipelining isn't directly related to your question, but is often described in conjunction with Keepalives and other HTTP efficiency features, so I decided to include it in this answer for completeness)
Now we can finally come back to your question:
Is a TCP three-way handshake required for an HTTP POST?
If you open a connection to a web server and download a webpage using the GET method, and that webserver supports connection keepalive. Subsequent requests to that web server, including the POST method, might simply re-use the already existing TCP connection. Therefore, that particular POST would not require a new 3-way handshake, since the data would be transferred in an already existing TCP connection.
Connection Keepalive, however, does not have an infinite duration. So if after downloading the webpage, you waited a while before sending your POST, the original TCP connection may have already closed, and in this case, your browser would have to open a new TCP connection to POST your data, which would obviously require starting with the 3-way handshake.
Since many browsers and webservers use different timers for how long they want their "connection keepalive" feature to keep connections alive, I wouldn't be able to give you reliable numbers as to how long they typically last.
Eddie
  • 14,808
  • 42
  • 82
    This is a more complete answer. Thanks a lot. Definitely worth to be upvoted. – Manikandan Sigamani Nov 22 '16 at 18:56
    How about illustrating HTTP/2 :p? – animaacija Jan 25 '17 at 23:49
  • Actually, three-way handshake is not the only way to open TCP connections. To mention the other ways, there are simultaneous connection open and split handshake at least. – juhist Mar 05 '17 at 13:04
    The world would be a better place if all the answer would be detailed like this one! Well done, very well explained. – dawez May 24 '18 at 20:53
  • With a TCP-optimizing router or a proxy, the browser may start sending HTTP data on seeing a fake TCP connection establishment from the local agent when the server is still establishing the connection with the outermost piece of the client's environment. And let's think a minute if a TCP optimizer runs in the middle or in the server environment! – eel ghEEz Dec 17 '18 at 18:52
    This is the best answer. Simple, clear, with details. – Xin Jan 05 '20 at 14:36
  • So, when I'm logged into my `Fb account` and click on the `Home` button after some time then since this is a HTTP request does it mean that the connection between the server and the browser is over and 3-way handshake will be needed? – asn Jan 28 '20 at 23:12
  • @ajaysinghnegi It depends on FB's Connection Keepalive settings. But likely, if it has indeed been some time *(and the facebook isn't exchanging data with the server in the background)*, then yes, it will be a new connection and therefore new TCP 3-way handshake. But again, there is no way to tell for certain without capturing the packets. – Eddie Jan 29 '20 at 04:28
  • @Eddie BTW, ending of connection **doesn't** logs me OUT but what does that mean in this context? Why do we say it as `ending of connection`? – asn Jan 29 '20 at 07:39
  • @ajaysinghnegi Facebook (and most websites) use cookies to save your session data across multiple TCP connections. So connections can start and end independent of your logged in status of Facebook. – Eddie Jun 16 '21 at 15:55
13
Both HTTP GET and HTTP POSTS use TCP. If you are asking whether a POST also requires a 3-way TCP handshake (syn-synack-ack), it does just like any other TCP connection. The TCP handshake is required before any application protocol (such as HTTP) starts work.
FYI, your three-way handshake is incorrect; it should be "syn-synack-ack"
ADD:
If browser use QUIC (Quick UDP Internet Connections, pronounced quick. Proposed by Google) protocol for HTTP is possible to avoid 3-way TCP handshake. But AFAIK it supported in Chrome and Google.
Most software prefer HTTP/2 which still TCP but wit many features it use persistent connection then 3-way handshake done once for each server server.
If this protocols is used, 3-way hanshake can be avoided by any request, including GET.
mmv-ru
  • 754
Indeed. But anyways, there's still a way to make it more efficient — data can be put into SYN-SYNACK-ACK packets, although until the handshake's done, the data can't be used.
poige
  • 103
