Why does the "show adjacency" command take so long to run (in the order of minutes) on Cisco IOS Software, 7200 Software (C7200P-SPSERVICESK9-M), Version 12.4(4)XD5, RELEASE SOFTWARE (fc1)? The router is an Internet edge router running BGP? What do the "(5)", "(10003)", or "(75845)" mean after the addresses? It seems to enumerating mostly addresses on a directly connected /23 network. CPU is < 2% and memory don't seem to be cause for this.
r-x-y-edge1#sh adjacency
Protocol Interface                 Address
IP       GigabitEthernet0/2        x.67.155.9(5)
IP       GigabitEthernet0/2        x.67.155.8(5)
IP       GigabitEthernet0/2        x.67.155.11(5)
IP       GigabitEthernet0/2        x.67.155.10(5)
IP       GigabitEthernet0/2        x.67.155.13(5)
IP       GigabitEthernet0/2        x.67.155.12(5)
IP       GigabitEthernet0/2        x.67.155.15(5)
IP       GigabitEthernet0/3        172.31.4.130(10003)
IP       Serial1/0                 point2point(75845)
<truncated>
CPU utilization for five seconds: 2%/1%; one minute: 3%; five minutes: 3%
Processor Pool Total:  864815572 Used:  547631528 Free:  317184044
      I/O Pool Total:   67108864 Used:    4520592 Free:   62588272
Is there a way to interrupt the execution of this command short of closing the session as Ctrl-^x doesn't have any effect?
Bulki
  • 2,363
  • 43
generalnetworkerror
  • 7,094
  • 32
  • 65
Have you checked to see if you have domain lookup disabled? (no ip domain lookup)
It could be that your command is taking so long to come back as it is trying to resolve all of the IP's to hostnames.
David Rothera
  • 2,788
  • This is an interesting suggestion - I wouldn't think that IOS would attempt to do name resolution for CEF adjacency entries since the majority of them will represent prefixes with a length < 32. – John Jensen May 27 '13 at 12:06
  • I had "ip domain name" and "ip domain list" configured, but no "ip name-server". Setting a couple of name-servers made the output display almost instantly. – generalnetworkerror May 28 '13 at 05:18
  • That's super awesome! Love learning new things. – John Jensen May 28 '13 at 05:43
  • Great catch @David, didn't occur to me either. Not as well-known DNS woe as lack of 'transport preferred none' under line VTY :) – ytti May 28 '13 at 07:29
  • Thanks for the comments from the more experienced network engineers in the group; I don't feel as bad that it was a reverse lookup that stumped me. – generalnetworkerror May 28 '13 at 21:18
The value in parentheses refers to the number of times a FIB entry points to an adjacency entry. Mentioned here.
Adam Loveless
  • 3,129
  • 30
  • 51
Is the router taking full tables? If it is, I guess I wouldn't be surprised that it's taking a long time, seeing as how it has to resolve however many networks that represents a full table to an exit interface (RIB->FIB). Also remember that the 7200 is still a software based forwarding platform. You still have 3 more layers of CEF above you in terms of which ones are faster.
If a large number of those adjacencies are punt adjacencies (an entry that would have to be punted to the next-level switching method) or glean adjacencies, this may also explain why it's taking a long time - and I'd imagine that a large number of them would be - again, still assuming it's a full table here.
The number in parentheses is called the refcount, and represents the number of times that adjacency is pointed to by FIB entries.
Edit: regarding canceling the command, try Ctrl+C (repeatedly) - sometimes this works for me for killing long-running commands. OTOH if I know the command will produce a lot of output, I'll set "terminal length" to something like "50", that way I have the option of killing the command by way of output pagination.
John Jensen
  • 8,997
  • 47
  • Hi John, I'm not sure I follow the comment about 3 more layers of CEF... can you elaborate? – Mike Pennington May 27 '13 at 17:14
  • Sure - in general I was talking about the "best" (according to Cisco) switching methods, in order: hardware dCEF -> hardware CEF -> PXF switching -> software-based CEF -> fast switching -> process switching – John Jensen May 27 '13 at 18:06
  • But I am not seeing why it's relevant to mention other switching paths... AFAIK, other switching paths being more efficient at moving packets has nothing to do with the time it takes to dump the adjacency table on a 7200 router. – Mike Pennington May 27 '13 at 18:13
  • It was relevant to my point that a 7200 is a software based platform rather than something like a cat65k or a 7600 which does CEF in hardware; it would seem like it would be a safe assumption that a platform that does CEF in hardware would perform a little snappier at dumping adjacencies, would it not? Being totally honest though my experience with 7200's in production is limited - I've always been "lucky" enough to work with the bigger ASIC- based multi-stage boxes. – John Jensen May 27 '13 at 19:11
