I am trying to monitor individual transceivers on two EX8216 Juniper switches regarding the following parameters:
  • RxPower
  • TxPower
  • Bias Current
  • Temperature
The methodology I am following is the following: I do an SNMP walk on the 1.3.6.1.2.1.2.2.1.2 (ifDescr) OID to view the switches' interfaces and I identify the indexes of the transceivers I am interested in. Having identified the correct indexes I use the Juniper jnxDomCurrentTable MIB to identify the OID of the aforementioned parameters that I want to monitor. Namely, the OIDs I am using are the following:
 - jnxDomCurrentRxLaserPower :.1.3.6.1.4.1.2636.3.60.1.1.1.1.5.
 - jnxDomCurrentTxLaserBiasCurrent : .1.3.6.1.4.1.2636.3.60.1.1.1.1.6.
 - jnxDomCurrentTxLaserOutputPower: .1.3.6.1.4.1.2636.3.60.1.1.1.1.7.
 - jnxDomCurrentModuleTemperature: .1.3.6.1.4.1.2636.3.60.1.1.1.1.8.
However, when I do SNMP GETs on the two EX8216 switches I do not retrieve any values, instead I receive a message that the OID does not exist: "No Such Instance currently exists at this OID".
The methodology I am following works fine for two MX960 Juniper devices and I am able to monitor the parameters mentioned above. However, it does not for the two EX8216 switches.
Thus my questions are:
  1. Do EX8216 Juniper switches support the Juniper Digital Optical Monitoring MIB?
  2. If they do support this MIB, do I have to do something further to enable SNMP polling of individual transceivers on the switches for the specific OIDs I mentioned above?
  3. Finally, if they do not support it, is there another way to SNMP poll those switches for the parameters I am interested in?
I would be grateful for any pointers or advice on how to go about achieveing my goal.
infra
  • 3,098
SC21
  • 81
  • Can you paste the output of "show chassis hardware detail" and "show version"? – Jordan Head Nov 06 '14 at 09:13
  • SNMP is a big ole pile of crap, isn't it. See if the Juniper has something like Cisco's Enterprise Event Manager, or some type of syslog solution. Or, keep banging your head against SNMP. Are you sure you are not sending SNMP community strings (passwords) in clear text across your network? – Ronnie Royston Jun 03 '15 at 22:24
  • SNMP is incredibly powerful with low overhead and extremely secure (when using v3). – Ryan Foley Jun 04 '15 at 17:15
  • Did any answer help you? if so, you should accept the answer so that the question doesn't keep popping up forever, looking for an answer. Alternatively, you could post and accept your own answer. – Ron Maupin Jan 03 '21 at 19:40
Unfortunately the DOM MIB does not seem to be supported on any of the EX 22/32/42/82xx switches. I've been bitten by this in the past.
The values are present on the device eg: show interfaces diagnostics optics xe-1/1/0, but not exported into the MIB tree.
Benjamin Dale
  • 9,296
From what I understand, the DOM MIB will only work with 10G XFP optical only, no support for 1G SFP yet unfortunately. See Juniper MIB References
Jaxxs
  • 395
  • Jaxxs thank you for your answer. You are correct that the DOM MIB is used for XFPs. Indeed the interfaces for which I can get values on the two MX960 Juniper routers are 10G XFPs. However, although the interfaces I want to monitor on the EX8216 switches are also 10G XFPs, I can't seem to get any values. – SC21 Oct 07 '14 at 06:32
  • Are you using the XFP transceivers in an SFP+ line card? If so that could be the reason. The clock for the XFP is contained within the transceiver itself, and the clock for SFP+ moves it onto the line card. – Jaxxs Oct 07 '14 at 13:45
