Situation:
I am trying to get 802.1X working for me. I want RADIUS server to dynamically assign VLANs to ports based on RADIUS reply attribute for particular user. I have an HP E2620 switch and a FreeRADIUS server. The supplicant is a Windows 8.1 machine
I referred to this document on freeradius website.
What I've done so far:
On FreeRADIUS I created a user with such parameters:
dot1xtest User-Password := "secret"
Tunnel-Type = "VLAN",
Tunnel-Medium-Type = "IEEE-802",
Tunnel-Private-Group-ID = "100"
I also tried Tunnel-Pvt-Group-ID
instead, but it doesn't work on FreeRADIUS, just barks at me (I saw this on resources for configuring on Microsoft NPS, one of these)
. Also I tried values "802", 802, 6 for tunnel medium type.
Also I tried to use actual VLAN name instead of VLAN-ID as Group ID value. Anyway its datatype is string.
I configured the HP switch to use this RADIUS server for AAA and set this up for port 10:
aaa port-access gvrp-vlans
aaa authentication port-access eap-radius
aaa port-access authenticator 10
aaa port-access authenticator 10 auth-vid 150
aaa port-access authenticator 10 unauth-vid 200
aaa port-access authenticator active
VLANs:
VLAN 100 - VLAN which I want to get after authentication.
VLAN 150 - VLAN which I get now, because my config is not working
VLAN 200 - Unauthorized VLAN which is used on auth. failure
Notes:
Port 10 also has untagged VLAN 150 assigned to it:
vlan 150 untagged 10
. And I can't get rid of the static assignmentAll VLANs listed above are present in switch's VLAN database.
Whenever I plug into this port it asks me for credentials; after I succeed with authentication it just sends me to VLAN150 and if I try to fail I get to VLAN200.
I enabled 802.1X authentication on Windows connection just like described here.
I tried enabling GVRP - it doesn't change anything
Diagnostic/show command output:
Static VLAN assignment for Port 10. VLAN 150 untagged
SW # show vlans ports 10 detail
Status and Counters - VLAN Information - for ports 10
VLAN ID Name | Status Voice Jumbo Mode
150 VLAN150 | Port-based No No Untagged
In show logging
I see this:
I 08/28/14 08:29:24 00077 ports: port 10 is now off-line
I 08/28/14 08:29:29 00435 ports: port 10 is Blocked by AAA
I 08/28/14 08:29:29 00435 ports: port 10 is Blocked by STP
I 08/28/14 08:29:29 00076 ports: port 10 is now on-line
I 08/28/14 08:29:29 00001 vlan: VLAN200 virtual LAN enabled
I 08/28/14 08:29:29 00002 vlan: UNUSED virtual LAN disabled
I 08/28/14 08:29:29 00001 vlan: UNUSED virtual LAN enabled
I 08/28/14 08:29:47 00002 vlan: UNUSED virtual LAN disabled
show port-access authenticator
output:
SW # show port-access authenticator
Port Access Authenticator Status
Port-access authenticator activated [No] : Yes
Allow RADIUS-assigned dynamic (GVRP) VLANs [No] : Yes
Auths/ Unauth Untagged Tagged % In RADIUS Cntrl
Port Guests Clients VLAN VLANs Port COS Limit ACL Dir
10 1/0 0 150 No No No No both
RADIUS user test:
Linux-server # radtest dot1xtest secret localhost 0 secretkey
Sending Access-Request of id 158 to 127.0.0.1 port 1812
User-Name = "dot1xtest"
User-Password = "secret"
NAS-IP-Address = 127.0.0.1
NAS-Port = 0
Message-Authenticator = 0x00000000000000000000000000000000
rad_recv: Access-Accept packet from host 127.0.0.1 port 1812, id=158, length=37
Tunnel-Type:0 = VLAN
Tunnel-Medium-Type:0 = 802
Tunnel-Private-Group-Id:0 = "100"
This is what I saw in TCPdump on the RADIUS server. I was capturing outgoing UDP traffic with source port 1812. It's what my switch gets (if it does actually, not sure how to check that...)
Tunnel Type Attribute (64), length: 6, Value: Tag[Unused]#13
0x0000: 0000 000d
Tunnel Medium Attribute (65), length: 6, Value: Tag[Unused]802
0x0000: 0000 0006
Tunnel Private Group Attribute (81), length: 5, Value: 100
0x0000: 3130 30
Debug:
debug security radius-server
debug security port-access authenticator
debug destination buffer
After that I unplugged and plugged in the cable and did show debug buffer
and here is the copy-paste of it. It's weird, nothing is said about any attributed related to VLAN.
Questions:
What am I doing wrong?
I've read in a bunch of resources that if the RADIUS assigns a VLAN ID switch uses that in the first place. Then it falls back to Authorized VLAN configured for Port-Access Authenticator if authentication succeeds. If that is not present it assigns Untagged VLAN configured on the port. Why don't I get that behavior?
I kind of start to think the attribute Tunnel-Private-Group-Id
is not supported on these switches. It seems every resource refers to Tunnel-Pvt-Group-Id
instead (configuring on Microsoft). Too bad I don't have Windows Server to check.
Maybe it's firmware related? Didn't try to upgrade yet, I use RA_15_06_0009.swi and there's RA_15_14_0007.swi out there already
Update
Just tried on a 3500yl-24G-PWR
model and still doesn't work. So.. I'd guess, switches just don't get the config from the RADIUS server (or did I use incorrect attributes or operators?). How can I troubleshoot that?
