I have encountered something I'm not familiar with in a customer's configuration, I know that the "(hitcnt=324165)" at the end of every rule in "show access-list" points to rule usage, hit count. But in this output of show access-list I'm also seeing numbers following object and non-object entities in the rule.
Example
access-list access-global-in line 5 extended deny ip object-group HA_Networks_All any log
 informational interval 300 0xf688d263
access-list access-global-in line 5 extended deny ip object-group HA_Networks_All(298) any(65537) log
 informational interval 300 (hitcnt=324165) 0xa2669c62
access-list access-global-in line 7 extended deny ip object-group HA-Wireless_10.1.80.0-24 any log
 informational interval 300 0xb25caeed
access-list access-global-in line 7 extended deny ip object-group HA-Wireless_10.1.80.0-24(299)
 any(65537) log informational interval 300 (hitcnt=2133314) 0x111a2d28
Notice that the same rule is displayed twice (same line number) but once with the parentheses inside the rule and once without.
Is this some sort of object usage? If so how can it be different from the hit count? I couldn't find any documentation explaining this.
Mike Pennington
  • 29,876
  • 78
  • 152
Harnik
  • 433
  • Did any answer help you? If so, you should accept the answer so that the question doesn't keep popping up forever, looking for an answer. Alternatively, you can post and accept your own answer. – Ron Maupin Jan 03 '21 at 05:57
Great question! You're right in thinking that it is a function of your object-group.
You have ACL optimisation activated. This is activated via the global CLI command object-group-search access-control .
ACL optimisation collapses all the possible ACE combinations for source/destination addresses and ports back into your original objects. The numbers in parentheses are the amount of entries that have been collapsed into that single entry.
When ACL optimisation is disabled, the show access-list command will show you the expanded entries instead.
The object-group-search access-control command is service affecting and will drop connections while it is performing the algorithm.
Mike Pennington
  • 29,876
  • 78
  • 152
mbud
  • 559
    First of all, thank you mbud for your answer, but Mike is right. My question is about the parentheses that follow the objects within the rule, since these examples are of "deny/permit ip" ACLs and we see the number after network objects I don't think these are port numbers. Also please notice that the number that follows "Any" on the ACL Mike took for an example is 65537, either too high to be a port number or suspiciously close... :) Still in the dark about this. – Harnik Jul 30 '14 at 07:11
    Okay so I think I've figured it out. You must have object-group optimisation turned on. `object-group-search access-control` Object-group optimisation stops the behaviour I described above. It collapses all the possible combinations for source/destination addresses and ports back into your original objects. The numbers in parentheses are the amount of entries that have been optimised to that single ACE. – mbud Jul 30 '14 at 14:10
