113
I've heard it suggested that "solid tantalum" capacitors are dangerous and may cause fire, may fail short circuit and are fatally sensitive to even very short over voltage spikes.
Are tantalum capacitors reliable?
Are they safe for use in general circuits and new designs?
Russell McMahon
  • 147,325
  • 210
  • 386
    Tantalum capacitors are safe if used properly, just kindof dumb in new designs nowadays. Between multi-layer ceramics and solid aluminum, there is really very little reason to use a tantalum in a new design today. – Olin Lathrop Feb 10 '14 at 21:13
    Somebody downvoted this. It was asked as a tutorial question in oder to give the answer below (which is an approved Stack Exchange method of creating a tutorial). Given the 41 question upvotes and 54 answer upvotes, I'd suggest that the sole downvoter "has problems". – Russell McMahon Dec 20 '15 at 10:45
    I upvoted both the question and answer long ago, but there are some here who downvote these kinds of questions for unknown reasons. As you've probably realized by now, once you get high rep, you have a target on your back, and people will downvote your posts for the slightest reasons or "just because". For example, see http://electronics.stackexchange.com/q/34745/4512. That's a question and answer much like this one, with the question getting 4 downvotes and the answer 1. Fortunately that's miniscule in the overall rep. This will continue as long a downvoting here is anonymous. – Olin Lathrop Dec 20 '15 at 13:41
6 Answers6
128
Summary:
"When used properly" tantalum capacitors are highly reliable.
They have the advantage of high capacitance per volume and good decoupling characteristics due to relatively low internal resistance and low inductance compared to traditional alternatives such as aluminum wet electrolytic capacitors.
The 'catch' is in the qualifier "when used properly".
Tantalum capacitors have a failure mode which can be triggered by voltage spikes only 'slightly more' than their rated value. When used in circuits that can provide substantial energy to the capacitor failure can lead to thermal run-away with flame and explosion of the capacitor and low resistance short-circuiting of the capacitor terminals.
To be "safe" the circuits they are used in need to be guaranteed to have been rigorously designed and the design assumptions need to be met. This 'does not always happen'.
Tantalum capacitors are 'safe enough' in the hands of genuine experts, or in undemanding circuits, and their advantages make them attractive. Alternatives such as "solid aluminum" capacitors have similar advantages and lack the catastrophic failure mode.
Many modern tantalum capacitors have built in protection mechanisms which implement fusing of various sorts, which is designed to disconnect the capacitor from its terminals when it fails and to limit PCB charring in most cases.
If 'when', 'limit' and 'most' are acceptable design criteria and/or you are a design expert and your factory always gets everything right and your application environment is always well understood, then tantalum capacitors may be a good choice for you.
Longer:
Solid Tantalum capacitors are potentially disasters waiting to happen.
Rigorous design and implementation that guarantees that their requirements are met can produce highly reliable designs. If your real world situations are always guaranteed to not have out of spec exceptions then tantalum caps may work well for you, too.
Some modern tantalum capacitors have failure mitigation (as opposed to prevention) mechanisms built in. In a comment on another stack exchange question Spehro notes:
  • The data sheet for Kemet's Polymer-Tantalum caps says (in part) : "The KOCAP also exhibits a benign failure mode which eliminates the ignition failures that can occur in standard MnO2 tantalum types.".
Strangely, I can find nothing about the "ignition failure" feature in their other data sheets.
Solid Tantalum electrolytic capacitors have traditionally had a failure mode which makes their use questionable in high energy circuits that cannot be or have not been rigorously designed to eliminate any prospect of the applied voltage exceeding the rated voltage by more than a small percentage.
Tantalum caps are typically made by sintering tantalum granules together to form a continuous whole with an immense surface area per volume and then forming a thin dielectric layer over the outer surface by a chemical process. Here "thin" takes on a new meaning - the layer is thick enough to avoid breakdown at rated voltage - and thin enough that it will be punched through by voltages not vastly in excess of rated voltage. For an eg 10 V rated cap, operation with say 15V spikes applied can be right up there with playing Russian Roulette. Unlike Al wet electrolytic caps which tend to self heal when the oxide layer is punctured, tantalum tends not to heal. Small amounts of energy may lead to localised damage and removal of the conduction path. Where the circuit providing energy to the cap is able to provide substantial energy the cap is able to offer a correspondingly low resistance short and a battle begins. This can lead to smell, smoke, flame, noise and explosion. I've seen all these happen sequentially in a single failure. First there was a puzzling bad smell for perhaps 30 seconds. Then a loud shrieking noise, then a jet of flame for perhaps 5 seconds with gratifying wooshing sound and then an impressive explosion. Not all failures are so sensorily satisfying.
Where the complete absence of overvoltage high energy spikes could not be guaranteed, which would be the case in many if not most power supply circuits, use of tantalum solid electrolytic caps would be a good source of service (or fire department) calls. Based on Spehro's reference, Kemet may have removed the more exciting aspects of such failures. They still warn against minimal overvoltages.
Some real world failures:
Wikipedia - tantalum capacitors
  • Most tantalum capacitors are polarized devices, with distinctly marked positive and negative terminals. When subjected to reversed polarity (even briefly), the capacitor depolarizes and the dielectric oxide layer breaks down, which can cause it to fail even when later operated with correct polarity. If the failure is a short circuit (the most common occurrence), and current is not limited to a safe value, catastrophic thermal runaway may occur (see below).
Kemet - application notes for tantalum capacitors
  • Read section 15., page 79 and walk away with hands in sight.
AVX - voltage derating rules for solid tantalum and niobium capacitors
  • For many years, whenever people have asked tantalum capacitor manufacturers for general recommendations on using their product, the consensus was “a minimum of 50% voltage derating should be applied”. This rule of thumb has since become the most prevalent design guideline for tantalum technology. This paper revisits this statement and explains, given an understanding of the application, why this is not necessarily the case.
With the recent introduction of niobium and niobium oxide capacitor technologies, the derating discussion has been extended to these capacitor families also.
Vishay - solid tantalum capacitor FAQ
  • . WHAT IS THE DIFFERENCE BETWEEN A FUSED (VISHAY SPRAGUE 893D) AND STANDARD, NON-FUSED (VISHAY SPRAGUE 293D AND 593D) TANTALUM CAPACITOR?
A. The 893D series was designed to operate in high-current applications (> 10 A) and employs an “electronic” fusing mechanism. ... The 893D fuse will not “open” below 2 A because the I2R is below the energy required to activate the fuse. Between 2 and 3 A, the fuse will eventually activate, but some capacitor and circuit board “charring” may occur. In summary, 893D capacitors are ideal for high-current circuits where capacitor “failure” can cause system failure.
Type 893D capacitors will prevent capacitor or circuit board “charring” and usually prevent any circuit interruption that can be associated with capacitor failure. A “shorted” capacitor across the power source can cause current and/or voltage transients that can trigger system shutdown. The 893D fuse activation time is sufficiently fast in most instances to eliminate excessive current drain or voltage swings.
Capacitor guide - tantalum capacitors
  • ... The downside to using tantalum capacitors is their unfavorable failure mode which may lead to thermal runaway, fires and small explosions, but this can be prevented through the use of external failsafe devices such as current limiters or thermal fuses.
What a cap-astrophe
  • I was working at a manufacturer that was experiencing unexplained tantalum-capacitor failure. It wasn't that the capacitors were just failing, but the failure was catastrophic and was rendering PCBs (printed-circuit boards) unfixable. There seemed to be no explanation. We found no misapplication issues for this small, dedicated microcomputer PCB. Worse yet, the supplier blamed us.
I did some Internet research on tantalum-capacitor failures and found that the tantalum capacitors' pellets contain minor defects that must be cleared during manufacturing. In this process, the voltage is increased gradually through a resistor to the rated voltage plus a guard-band. The series resistor prevents uncontrolled thermal runaway from destroying the pellet. I also learned that soldering PCBs at high temperatures during manufacturing causes stresses that may cause microfractures inside the pellet. These microfractures may in turn lead to failure in low-impedance applications. The microfractures also reduce the device's voltage rating so that failure analysis will indicate classic overvoltage failure. ...
Related:
AVX - surge in solid tantalum capacitors
Failure modes and mechanisms in solid tantalum capacitors - Sprague / IEEE abstract only. - OLD 1963.
AVX - FAILURE MODES OF TANTALUM CAPACITORS MADE BY DIFFERENT TECHNOLOGIES - Age ? - about 2001?
Effect of Moisture on Characteristics of Surface Mount Solid Tantalum Capacitors - NASA with AVX assistance - about 2002?
Hearst - How to spot counterfeit components
Sometimes it's easy :-) :
Added 1/2016:
Related:
Test for reverse polarity for standard wet-aluminium metal can capacitors.
Brief:
For correct polarity can potential is ~= ground. For reverse polarity can potential is a significant percentage of applied voltage.
A very reliable test in my experience.
Longer:
For standard wet Al caps I long ago discovered a test for reverse insertion which I've not ever seen mentioned elsewhere but is probably well enough known. This works for caps which have the metal can accessible for testing - most have a convenient clear spot at top center due to the way the sleeve is added.
Power up circuit and measure voltages from ground to can of each cap. This is a very quick test with a volt-meter - -ve lead grounded and zip around cans.
  • Caps of correct polarity have can almost at ground.
  • Caps of reverse polarity have cans at some fraction of supply - maybe ~~~= 50%.
Works reliably in my experience.
You can usually check using can markings but this depends on intended orientation being known and clear. While that is usually consistent in a good design this is never certain.
Glorfindel
  • 1,245
Russell McMahon
  • 147,325
  • 210
  • 386
    Excellent and detailed write-up. – Spehro Pefhany Feb 10 '14 at 19:37
  • @jippie - thanks - yes, there was a single typo there, but it made it appear that there were several in a row as the sentence then 'did not scan'. I imagine that there will be more typos there yet. Our brains tend to skim over these at first - even more so when you are the writer. Here "stp" should have read "to". (I imagine that the added leading 's' occurred as I struck "d" somewhat too far to the left, and "p" is to the right of "o". Hence [S]T[o->P]. Also "smell" means "create a bad odour" and this is less obvious with the typo. – Russell McMahon Feb 10 '14 at 20:48
    +1 for "Not all failures are so sensorily satisfying..." :-) – TimH - Codidact Feb 10 '14 at 20:50
  • Firefox has a spelling checker and I double checked the spelling of the article. You are correct there are couple other typo's, but non of them are annoying to the (Dutch) eye. The sentence that mentioned before was somewhat tough to decipher. Anyways, nice write-up. I still feel confident to use tantalums but I now know what to look out for. And I know I've been lucky in the past ... ;o) – jippie Feb 10 '14 at 21:16
    How far are you from the nearest dire department station and what's their response time? – Ben Voigt Feb 10 '14 at 23:59
    Citing Kemet: "The short-circuit failure may thereby be converted to an open-circuit failure." - nice way to say "The device will explode." :) – Volker Siegel Nov 27 '14 at 04:57
    Nice, My biggest problem with tantalum's is that they will often survive for a long time when put in backwards. (I use tant's conservatively with voltage rating 3-4 times what is applied.) This means that a product can pass testing and then fail in the field. The longest time delay "bomb" that we've shipped so far had a 35V tant on a 5 V regulator... it lasted five years (of intermittent operation) till it let out the magic smoke and triggered a phone call. – George Herold Jan 07 '16 at 17:44
  • @GeorgeHerold For std wet Al caps I long ago discovered a test for reverse insertion which I've not ever seen mentioned elsewhere but is probably well enough known. This works for caps which have the metal can accessible for testing - most have a convenient clear spot at top centre due to the way the sleeve is added. | Power up circuit and measure voltages from ground to can of each cap. This is a very quick test with a volt-meter - -ve lead grounded and zip around cans. Caps of correct polarity have can almost at ground. .... – Russell McMahon Jan 07 '16 at 20:39
  • .... Caps of reverse polarity have cans at some fraction of supply - maybe ~~~= 50%. Works reliably in my experience. You can usually check using can markings but this depends on intended orientation being known and clear. While that is usually consistent in a good design this is never certain. – Russell McMahon Jan 07 '16 at 20:40
  • 1) The first bullet-point in the "Longer" section has an orphaned fragment: "these particular tantalum caps". I can't figure out what it should read to edit it. 2) They used a *Rubycon* capacitor in a fake? – Andrew Morton Jun 27 '16 at 09:58
  • @AndrewMorton Thanks. Could make no certain sense of it and was there from very 1st edit so I deleted it. | Rubycon - have to keep the quality consistent :-) – Russell McMahon Jun 27 '16 at 11:04
    Large (size D and up) MnO2 tantalums are damaged by the mere act of reflow: http://www.kemet.com/Lists/TechnicalArticles/Attachments/21/2002%20CARTS%20PowerOn%20Failures.pdf – Peter Smith Feb 01 '17 at 13:27
  • My experience of a tant failing when I was working on the board was a blue flash, a bang and a piece of the case stuck deep enough in my finger to draw blood – Dirk Bruere Feb 01 '17 at 14:03
  • Is it possible to solve the problem by placing a zener diode in parallel with the capacitor? – Demi Oct 01 '18 at 23:38
  • @Demi No - if a zener is the only protection means. My 1st 3 paragraphs apply, and a zener alone clearly does not meet them. The main issue is that a zener has a very soft voltage/current "knee" - the voltage rises considerably as the current increases from zero to the zener's rated maximum. So, if you set the zener voltage such that it will absorb all spike energy while below capacitor voltage, the zener will still draw substantial current at lower safe voltages. ... – Russell McMahon Oct 15 '18 at 12:02
  • ... If you increase the zener voltage it will draw less standing current but allow higher energy spikes to destroy the capacitor as voltage rises above safe level. A very sharp clamp is needed if this approach is taken. – Russell McMahon Oct 15 '18 at 12:02
  • @RussellMcMahon What are such clamps? – Demi Oct 15 '18 at 12:46
  • @Demi 4 years on :-) - and 2 yearsish since you've last logged in - you may yet see this. | An "electronic adjustable zener" such as a TL431 - either by itself or driving a pass element as a clamp will meet this need. So too would eg a comparator driving a MOSFET. there MAY be cases where doing this is justified due to some Tantalum magic factors, but usually just using another capacitor type would be easier. – Russell McMahon Jul 20 '22 at 09:18
With the advent of compact inexpensive high-value (10uF and beyond, rated at 6.3, 10, 16V and so on) X5R and X7R (reasonable dielectrics) ceramic capacitors there seems to be much less reason to consider tantalum capacitors.
One of the differences is that tantalum caps have an ESR that is of the order of ohms. On some LDO regulators, that's an advantage, in that the LDO won't oscillate like a banshee. In such cases, I'd prefer to use a ceramic capacitor and a series resistor.
On some sensitive analog circuits, I think there may be an advantage to tantalums over ceramic caps in reduced microphonics (in ceramic caps, due to piezo-electric activity).
Spehro Pefhany
  • 376,485
  • 842
    Recent LDOs (last 10 years or so) have been designed with ceramic caps in mind and are generally stable with a 0 ESR output cap. You do have to watch out that someone in your organization doesn't try to save a few m$ and gets a cheap batch of old LDOs designed for tantalum caps that rely on some minimum ESR. – Olin Lathrop Feb 10 '14 at 21:27
    Some of the old data sheets don't even bother mentioning a minimum allowable ESR, presumably because it was unthinkable at the time to have a capacitor that was too good. – Spehro Pefhany Feb 10 '14 at 22:05
  • Tantalum polymer capacitors are available with ESR on the order of 10s of mΩ. Ceramic is still lower ESR (though not available in as large capacitances), and aluminum polymer is cheaper for about the same ESR, though. – Hearth Jul 18 '22 at 14:59
One guideline in using them : if the current through the cap is strictly limited in the event of a failure, go ahead.
Limited to what? I would suggest 0.1A. I would feel wary of using them to decouple a 1A or higher supply rail, and would not personally use them across a 10A supply. (Been there, seen the fireworks; Russell's pictures do not exaggerate.) I have to say I have no hard evidence of a truly "safe" current and comment on these figures would be welcome.
But many supplies or bias voltages in analog circuitry have relatively high source impedances or strictly limited currents, and I would use them there.
EDIT based on new (to me!) information ...
At least one manufacturer is offering Niobium Oxide capacitors in very similar packaging and range of values and voltages. In what might be read as a tacit admission of tantalum's problems described here, the datasheet contains the statement "Failed OxiCap® will not burn up to category voltage" and a cute little logo...
[Disclaimer : I have neither used these capacitors nor attempted to verify the claim!]
  • Although a failure may not be as impressively destructive minus the "ignition" feature, I have to point out that it's still a failure. However, if the current is truly limited to only maybe 50-100mA, it may not fail. But that means their use in bypass applications is quite limited. – Spehro Pefhany Feb 10 '14 at 19:36
A short note on "why Tantalum instead of large MLCCs":
MLCCs with X5R and similar dielectrics are characterized at 0V bias. However, when running at e.g. 100% of rated voltage the effective differential capacity may only be 10% of the rated one (!). Especially very small caps with high voltage rating show a dramatic decrease in capacity when biased.
Example 1: 0402 MLCC, X5R, 10µF, 6.3V: 3.5µF left at about 3V.
Example 2: 0402 MLCC, X5R, 2.2µF, 25V: 1.0µF (!) left at about 3V.
That data is well shown in the online-datasheets from TDK.
user207421
  • 881
  • In the future please avoid large paragraphs. It is much easier to read a series of small ones, and more likely to get upvotes. For instance "Examples" could have been the start of a new paragraph, helping it to stand out with its own content and context. –  Jun 23 '16 at 16:21
  • While this answer has useful information, it does nothing to answer any of the questions. It's off topic as an answer, and would be better served as either a comment to one of the other answers, or as an answer to another question. – pipe Jun 23 '16 at 17:20
    @pipe I consider this answer a useful addition. we are often enough told that comments tend to be removed with time and ideally should not contain substantive content. | With the availability of large capacity ceramic capacitors they have become an attractive alternative to Tantalum caps in some cases - Jurgen points out why they may be less suitable as an alternative than they appear. – Russell McMahon Jun 23 '16 at 17:45
  • @RussellMcMahon Comment removal or not - this still does not answer the questions. There are a few questions on this site that deals _directly_ with the question `why Tantalum instead of large MLCCs`. It should be posted there, not in an unrelated question. – pipe Jun 23 '16 at 17:49
  • [Ceramic (MLCC) versus Tantalum capacitors](http://electronics.stackexchange.com/questions/199479/ceramic-mlcc-versus-tantalum-capacitors), [Tantalum capacitors vs. ceramic capacitors](http://electronics.stackexchange.com/questions/6647/tantalum-capacitors-vs-ceramic-capacitors) comes to mind. – pipe Jun 23 '16 at 17:52
  • @pipe re your comment on the deleted answer that I thus cannot comment on directly: His anecdotes are of his experiences so valid unless you are calling him a liar, and what he says is not hyperbole. Tantalum caps do fail just as he says and there was seldom a good reason to use them in applications where their subsequent failure was no surprise. One of my 'treasures' - long ago vanished, was a metal can tantalum cap with a hole melted in one side wall and a ball of fused tantalum rolling around inside & too large to exit via the hole. That is a DEC PDP-11 psu. A stupid choice on their part. – Russell McMahon Jun 23 '16 at 17:56
  • @pipe As I noted above - I have seen/heard/smelt them smell, shriek, flame and explode. I have seen them apply the hardest of hard shorts to power supply rails. Great fun they are :-). – Russell McMahon Jun 23 '16 at 17:58
  • @RussellMcMahon Hm, now I'm confused. The answer I'm commenting on is not deleted, nor does it talk about burning tantalums, which I agree is a fact - also from experience :). The answer I am talking about is this one I'm commenting on, by Jürgen, which talks about MLCCs. Your own question does not bring that up at all, or talk about alternatives. The question is about the pitfalls of tantalum capacitors, not about the pitfalls of other types. – pipe Jun 23 '16 at 18:06
  • @pipe :-) - Sorry - what I was trying to convey is that there is a comment by you on a deleted answer by Joe Mangan. As it is deleted I can't add comments there so have commented here to you re your comment there. – Russell McMahon Jun 24 '16 at 00:33
  • @RussellMcMahon Aaah ok, I can't see that either, hence the confusion... – pipe Jun 24 '16 at 00:46
    @pipe FYI only -[**here is the deleted question**](https://dl.dropboxusercontent.com/u/30808964/Screenshot%202016-06-24%2015.08.00_cropped.png) which I didn't realise you couldn't see. Again - fyi only, to close the loop. I'm NOT trying to disagree with you or prolong the discussion - I actually agree with you that his comments were anecdotal. It's just that his 'anecdotes' match mine and a number of associates ones well enough. WHY people used and use Tantalums in situations where disaster lurks I don't know but his somewhat unkind analysis of motivations does not seem entirely off the mark. – Russell McMahon Jun 24 '16 at 03:15
Some additional stuff from my side:
Yes, it can be stated that Tantalum Caps are safe.
They are not only used in the "rough" environment of consumer portable devices (notebook, smartphone - I never heard of a fire in a smartphone due to the caps) but are also utilized in medical implants such as heart pacemakers, cochlear implants or spinal cord stimulators.
With respect to reliability, the operating voltage has the strongest impact (much more than the temperature). The acceleration factor is
AF=exp{(V/VR-1)*18.772} according to the following NASA document: https://ntrs.nasa.gov/archive/nasa/casi.ntrs.nasa.gov/20110015254.pdf
For medical implants, the derating proposed by e.g. Vishay is 40% (so you would use a 16V cap for 10V or 10V rating for 6V applications). According to the upper formula the increase in lifetime is a factor of 1140.
Pls. do always keep in mind that there is no system which will not fail: The only question is the time for the cumulative error. I made my Master Thesis at Infineon. I think I can remember that the MOSFETs within safety-critical automotive systems had an allowed failure rate of 10ppm within 10.000hrs when operated on max. conditions (Temp & voltage)
Russell McMahon
  • 147,325
  • 210
  • 386
  • I do not disagree with your overall premises, but you also do not say anything technical that contradicts what I have said. Your opening statement that they are safe is "liable" to mislead people who do not dig deep enough to understand your useful and clear-enough but easily skimmed over formula. [The constant should be ~= **18.8** and not ~= 18800. ] The implications are that at 90% of rated voltage a Tcap has a failure "acceleration rate " of 0.15 and at 110% of rated voltage AccRate = 6.5. A change by a factor of 6.5/0.15 = 43:1 as Vapplied goes from 90% to 110% of Vrated. – Russell McMahon Feb 01 '17 at 12:37
  • The 1st 3 paragraphs of my answer fully cover what you say about professional use and proper "expert" design. I note the vastly increased risk of failure as Vrated is exceeded by small amounts, and the extremely interesting and useful paper that you cited confirms this. Your answer is useful, but many people could easily read it and draw the opposite conclusion to the correct one. Your suggested 40% voltage derating sounds sensible. (I get a factor of 1825 improvement at V=60% of Vr and ~= 12,000 at 50% of Vr. (And a factor of +12,000 at 150% of Vr :-) ). – Russell McMahon Feb 01 '17 at 12:47
  • AF=exp{(V/VR-1)*18.772} -> Better written as eg AF=exp[(V-VR)/VR*18.8] as while (V/VR-1) DOES mean ((V/VR)-1), as std operator precedence rules indicate, there may be doubt that this is so on inspection. | Also, the constant was originally written as "18,772" where the "," was a decimal point ie 18.772 or ~= 18.8. This MAY have been due to use of "," as a comma intentionally which is dangerous on an international site. If used correctly the provided formula is useful and interesting. Note that the "true" value for k may vary across about 10 to 28 and 18.77 is the compromise Mil Spec value. – Russell McMahon Feb 01 '17 at 12:57
There may be space-limited applications where tans are better, but that's about all. I avoid tans if I can. Common parts fail by letting the smoke out. They don't like high turn-on currents surges making them a poor choice for most power supply filtering. At least use the highest voltage part you can. They don't like high humidity which can hurt self-healing. Ceramics have gotten better and can replace them in many applications, as can aluminums some times.
Robert Endl
  • 2,197
