I want to pass some data from my verilog to my microblaze core in ISE 14.7. I was doing some research and it seemed like the FSL was the easiest way to go about this.
What I did was create a peripheral with one 32b input and one 32b output of the FSL variety. I then clicked configure coprocessor and added my new fsl_link to it.
That done, it added fsl_link_0_to_microblaze_0, microblaze_0_to_fsl_link_0, and fsl_link_0 to my Bus Interface window.
I then did a DRC check and I get
ERROR:EDK:3900 - issued from TCL procedure "::hw_fsl_v20_v2_11_f::check_syslevel_settings" line 14
fsl_link_0_to_microblaze_0 (fsl_v20) - FSL_Clk is unconnected.
microblaze_0_to_fsl_link_0 (fsl_v20) - FSL_Clk is unconnected.
All I want to do is pass some register values from my verilog to my uBlaze (doesn't even need to go the other direction for now). What am I doing wrong? I am not sure how I need to set up the clocks by my FPGA runs at 200MHz and my uBlaze is clocking at 100MHz if that helps.
JYelton
  • 32,302
  • 134
  • 249
toozie21
  • 111
Close the EDK and take a look at the system.mhs file. You should see the FSL clock and reset lines connected to sys_clk. If not, you can add them straight into that system.mhs file and re-generate the bitstream.
You need two lines like this in the BEGIN/END block
BEGIN fsl_v20
  PARAMETER ....
  PARAMETER ....
  PORT SYS_Rst = sys_rst
  PORT FSL_Clk = sys_clk
END
For a late night read, browse the FSL patent. It won't help you with your implementation, but I find it's always interesting to read up on a technology patent:
http://www.google.com/patents/US7380106
Brian Onn
  • 1,342
