I am making a water fountain feature and want to install a changing colour display that is variable in a laminar water jet. The unit has to be stand alone and start when the power is applied. The fountain is in the middle of a dam and is connected by a utility supply. Will the BlinkM MaxM do. I am able to do basic electronics and was hoping that this unit is suitable for the job. I am attaching acrylic rod to the LEDs as a light transmitter and this is insert into the water stream. I need bright LEDs. Can you recommend the electronics required for the job.
Doug
pfctdayelise
  • 103
the BlinkM maxm would be work well, but just remember you have to have a way to program it, with an Arduino or a usb programmer . the only other thing you would need would be a way to power it at the correct voltage.
jsolarski
  • 2,510
