According to this link ( and some other sources I have found ) more bandwidth on a wire means more bit rates per second...
Can someone try to explain why this is so as simple as possible?
This is all I know so far ( that I was able to learn by myself: )
-> Data is sent through a wire using frequency modulation, meaning, the voltage on the wire changes over time. At the end node, this signal is decoded.
-> A voltage in a specific frequency can be sent over a wire. ( Like a voltage change with a frequency of 5 Hz. ) That will be a sinusoidal signal.
-> To represent a data ( something like 10111001 ), you need to mix up a number of voltages in different frequencies so that it looks something more like: enter image description here
My exact questions are:
-> Can this be done with any frequencies that is chosen? For example, can I achieve the desired signal with using frequencies between 10 - 20 Herz, OR 50 to 60 Herz? Or do I need specific frequencies?
-> How does the bandwidth ( the frequency range I can use ) affect, how fast the signal goes on the wire? ( the bit rate? )
I am all trying to learn this stuff by myself with not much of an Electrical Engineering background, so if you can try to keep it simple, it would be very helpful.
Also any advise on background info that I require first is much appreciated.
Koray Tugay
  • 61
    The full answer is quite complex - an entire module of an undergraduate course - but start by researching Claude Shannon and "informatiion theory". – pjc50 Jan 25 '14 at 22:08
  • Also related: [What ultimately determines the speed of electrical media](http://electronics.stackexchange.com/questions/80824/what-ultimately-determines-the-speed-of-electrical-media/) – The Photon Jan 26 '14 at 01:04
  • Also related: [Difference between Hz and bps](http://electronics.stackexchange.com/questions/56265/difference-between-hz-and-bps/) – The Photon Jan 26 '14 at 01:05
  • In wireless communications you need higher frequencies than 50 or 60 Hertz because at lower frequencies (higher wavelength) the antenna size is quite large. At 50 or 60 Hertz the antenna size would be hundreds of kilometers in length. – Yasir Ahmed Feb 22 '18 at 17:51
  • Please look at this answer https://electronics.stackexchange.com/a/357973/175670 – Yasir Ahmed Feb 24 '18 at 06:41
  • It's actually: more bits per second means more bandiwdth. – user253751 Mar 17 '19 at 21:47
0 Answers0
