I've been trying to use this serial for android library now, but I can't make it work. I'm trying to run this little program in android:
    // MouseLib.ino
    #include "tracker.h"
    PositionTracker tracker(6,5);
    void setup() {
        Serial.begin(115200);
        tracker.init();
    void loop() {
        Serial.println("?");
        delay(20);
Where the tracker is as follows:
    #include "Arduino.h"
    #include "ps2.h"
    PositionTracker::PositionTracker(int _clkPin, int _dPin){
        // x = y = ldX = ldY = lX = lY = 0;
        clkPin = _clkPin;
        dPin = _dPin;
        sensor = new PS2(_clkPin, _dPin);
    void PositionTracker::init(){
        sensor->write(0xff);  // reset
        sensor->read();  // ack byte
        sensor->read();  // blank */
        sensor->write(0xf0);  // remote mode
        delayMicroseconds(100);
The code works fine when I plug Arduino to pc, but when i plug it in an Android device it just doesn't work. If I comment the "tracker.init()" line, it works fine for Android. If I use the example from ps2 library, it works fine as well. Oh, and I'm using the sample app for the serial library on a Moto G. Any ideas?
Links for the libraries:
EDIT
Right after posting this, I've found the issue: I was looking at the wrong website for the library. The answer was posted on their wiki already.
From the library's wiki (can't post the link, as I'm low on reputation):
Some Arduinos use the DTR line to determine serial channel readiness. In your Android code, call setDTR(true);
    Can you add your update as an answer and then accept it so that we can remove this from the unanswered queue? – Funkyguy Aug 14 '14 at 14:24
Right after posting this question, I've found the issue: I was looking at the wrong website for the library. The answer was posted on their wiki already.
From the library's wiki:
Library's wiki: https://github.com/mik3y/usb-serial-for-android/wiki/Troubleshooting#i-am-using-an-arduino-uno-sparkfun-pro-micro-or-other-arduino-and-if-serial-doesnt-work
