I've been playing with electronics for a long time, but am fairly new to digital electronics, including using Fritzing, so apologizes in advance for that.
I'm attempting a fairly basic 5VDC circuit where I want to use a thermistor to toggle a fan on and off, and to be able to set the point at which the fan toggles.
I know I could use Arduino to read the resistance from the thermistor and the potentiometer and, based on logic, supply high or low to the relay switch - but how would I build the circuit without an Arduino? Would I still need to use an IC for the logic?
I was thinking I could potentially use something like an AND/OR gate with the feedback from the thermistor circuit to control the relay ( thus giving the relay either high/low and not a variable voltage ) but the of course the AND/OR gate is going to get the variable voltage which seems wrong to me ( analog feedback to a digital component ) and so I know I'm missing something - a small I/C that can read the analog voltage would seem to be the "right" thing but it also seems like there may be an easier way to do it with such a simple circuit.
Below are the Schematic and Breadboard views from Fritzing. I know they are incomplete, and that the power supply is 6v instead of 5v, but hopefully it will help convey the basic idea.
screen.png http://img199.imageshack.us/img199/5462/ta07.png
screen 1.png http://img843.imageshack.us/img843/5582/q7yq.png
cwd
  • 375
    You want a comparator: http://en.wikipedia.org/wiki/Comparator , although it can be built out of half a dozen transistors if you prefer. – pjc50 Jan 12 '14 at 18:22
    You can use a single transistor solution, please read my reply [here](http://electronics.stackexchange.com/a/95967/33841). The LDR of that circuit can be replaced by a NTC or PTC thermistor. – alexan_e Jan 12 '14 at 18:39
  • thanks for the help, everyone! you really got me pointed in the right direction! – cwd Jan 12 '14 at 20:08
I think you should consider using an analogue component known as a comparator. It would compare the signal from your thermistor with a set-point set by a potentiometer and tthen output high or low depending on which is higher.
Wiki is quite useful on this and worth a read. You can also make a comparator from an op-amp and realistically this will work just as well for your application.
Vin is compared against Vth. Vth is set by R1 and R2 with a slight influence from R3. In your application, R1 and R2 would be a potentiometer, maybe 10k and R3 would be typically 1Mohm. R3 provides hysterisis that guarantees a certain level of protection against the comparator output "chattering" when Vin nearly equals Vth.
Rload in the circuit can be your relay coil.
