I have seen diode clamping/clipping circuits and can see that they can work well with such simple construction. However, what if we want to clamp/clip the current to some value rather than voltage?
Asked
Active
Viewed 338 times
Do you specifically mean some single-part mechanism like diodes, or would any combination of parts satisfy your query? – Anindo Ghosh Jan 09 '14 at 09:12
I just want to see a circuit that can be used to clip/clamp current to a desired value. It can be simple or made up of many parts. I am just curious to know how this is done. – quantum231 Jan 09 '14 at 09:46
1http://en.wikipedia.org/wiki/Current_limiting – JimmyB Jan 09 '14 at 09:59
1http://320volt.com/en/12v-ve-5v-600ma-irf9530-mosfetli-akim-sinirlama-devresi/ ... and for a 2-terminal device, a [constant-current diode](http://en.wikipedia.org/wiki/Constant-current_diode) – Anindo Ghosh Jan 09 '14 at 10:11
See also [The FET Constant-Current Source/Limiter](http://www.vishay.com/docs/70596/70596.pdf), the section on "Standard Two-Leaded Devices". – Tut Jan 09 '14 at 11:55
Here are a bunch of constant current circuits that I found while googling "contant current circuit: -
- This is the classic use of a transistor - the load is in the collector and you set the bias on the base so that there is a certain voltage across R1 - if that voltage is 3.3V then, due to R1 being 3k3, no more than 1mA can be passed to the load.
- If the LED (or load) tries to take more current than a certain value the lower NPN transistor starts to switch on the reduces the base voltage on the darlington thus current limiting is achieved.
- This is the classic use of the LM317 regulator chip
- This is a fairly simple and accurate current limit circuit. The voltage across R2 is held at (V+ -Vref) by action of the op-amp and transistor - this means the load (connected to the emitter) cannot draw more current than (V+ -Vref)/R2.
- This is the same as (4) (sorry, my mistake)
- This is very similar to (2) but works with a +V referenced load.
- This is similar to (4) and (5) but uses a MOSFET as the current limiting element.
With voltage limiting the word clamping is often used. With current, the term used is often "limiting".
- 28
- 351
- 777
