I would like to make a long range (5Km) quadcopter. As of right now, I'm just trying to find out the best way to control it. I know that there are some 5Km R/C transmitters but they are the size of brick which is a little inconvenient. I was wondering if communication could be made through GSM, GPS or other wireless protocol that would be cheaper and/or weigh less. Any ideas on how to achieve this long range is accepted.
GPS is navigation system and can not be used for navigation. As for any alternatives, I think that you're pretty much tied to brick size. GSM is not well suited, since it's difficult to send control signals through it and data modes such as GPRS aren't real-time enough for remote control, unless the UAV is very smart and just needs waypoints. – AndrejaKo Dec 26 '13 at 18:16
Check your flight regulatory authority as to whether you can fly quad copters at that range - UK treats them as r/c aeroplanes so require line of sight and a max distance of 500m. US requires line of sight, and I doubt you would see a quadcopter's attitude clearly at that range. – Pete Kirkham May 11 '14 at 09:30
4G :-) https://www.youtube.com/watch?v=7hA2orjUdCE – Ciro Santilli OurBigBook.com Aug 14 '16 at 17:32
An entirely practical consideration. If it's out of sight, some countries aren't happy that you continue. – Graham Stevenson Oct 11 '20 at 01:07
There are at least two commonly used civilian mechanisms for long range control of UAVs or RC cars: Public-band TX/RX radio, and mobile packet data, depending on the capabilities onboard the remotely controlled vehicle.
For public-band RF control at long range, modules such as the Xtend 900 1 Watt RSPMA by digi work well at 5+ miles, giving between 10 kbps and 115 kbps data rates, with very low power requirements. At 18 grams, they wouldn't be classed as "bricks".
These modules are a bit pricey, at nearly $200 each, including the cost of the antenna. The antenna itself would be a concern as well, as it would need to be fairly substantial, thus interfering with airflow. The most common type of antenna is the duck antenna, similar to those used in some wireless routers.
Note that the 900 MHz band is not available for public use in most countries other than the USA, Canada, Australia and a few others. Even in countries where it is permitted, the 1 Watt maximum power of this module may be far in excess of what the local telecom regulations permit.
While the marketing material suggests a 40 mile range for this device, realistic tests by aeromodelers indicate a usable range of 5 to 10 miles, less in areas with a lot of radio traffic in the 900 MHz band.
For a tighter budget, the XBee-Pro 900 XSC S3B, also from digi.com, would be worth experimenting with, albeit with some compromises:
These modules deliver around 10 kbps data rate, at a realistic range of perhaps 3 to 5 miles in line-of-sight. The marketing material suggests a 28 mile range, take that as you will.
The good thing is, the antenna is just a piece of wire soldered to the board, hence not so disruptive on an RC aircraft. Also, at a price point of ~ $70, these are much easier on the pocket.
The mobile packet data options are a bit more restrictive: Data rates are highly dependent on cell-site capacity, cell circuit availability and tower distance, and latency is widely variable. If the UAV has sufficient on-board intelligence that it essentially requires only occasional waypoint updates, and non-time-critical commands (e.g. "return to takeoff point at time X:YY and land"), this might be viable.
GPRS modules such as SM5100B from SparkFun are used by some RC enthusiasts. At under 9 grams weight, again these are not brick-sized. Also, the price is similar to the XBee-Pro 900 above.
Range can be arbitrarily high - so long as base controller and RC vehicle are both within range of cell towers for which network access is available to the respective units, the mechanism will work - even across countries, let alone miles, so long as latency and occasional signal drops are not an issue.
A good thought experiment would be to consider whether your RC vehicle communication could work by polling a web URL over the internet, for instance. If yes, then GPRS will work fine for the purpose.
It is worth keeping in mind that any such long-range RF remote control is affected by the vagaries of everything from sunspot activity to local weather conditions or someone using a cordless phone nearby to make a call. Hence, there should be little dependency on continuous control channel availability or data throughput. That being said, it's being done all the time, even in hostile terrains like the Antarctic, so have at it!
- 50,188
- 8
- 103
- 200
Thank you for the in depth analysis and given options. If I were to want to stream video as well, would you suggest one over the other? GSM also requires a sim card and monthly payments correct? – Riley Lloyd Dec 26 '13 at 20:32
@RileyLloyd I wouldn't consider streaming video over long range unless I had some pretty powerful video compression capability on board the UAV, and were willing to work with a very modest resolution and frame rate. In theory, you could stream video over both GPRS (ever watched YouTube over GPRS on a phone?) and Xtend, but it would be very sketchy and laggy. GPRS would require a mobile data subscription, yes. I have not suggested plain old GSM due to data rate constraints. – Anindo Ghosh Dec 26 '13 at 20:40
Would I be able to use the XBee Pro 900 U.FL Connection (https://www.sparkfun.com/products/9098) to use for control of the quadcopter and video transmission? or maybe use the original XBee you suggested for controls and this XBee for video? – Riley Lloyd Dec 26 '13 at 21:12
@RileyLloyd The XBee Pro 900 will most likely not work at 5 miles in real-world conditions - I've heard of it stuttering at less than 4 kilometers. Also, using two RF devices in the same frequency band at high power on one UAV... this will not end well. :-) – Anindo Ghosh Dec 26 '13 at 21:19
If the video cuts out it wouldn't be the end of the world as I would still hopefully have control via the other XBee. I am very new to the whole UAV and remote communications. I read that you can have different "signal numbers" (for lack of a better word) so that there is no cross communication. By not ending well do you mean too much battery usage? Why wouldnt it end well? Thank you for your continued help. – Riley Lloyd Dec 26 '13 at 21:38
@RileyLloyd Two devices, both transmitting in close proximity, both in the (presumably) same band, and both drawing power from a lightweight battery = An interesting variety of challenges. While I won't say it cannot be made to work, I wouldn't want to be the one spending money on the experiment :-) – Anindo Ghosh Dec 26 '13 at 22:18
And just to be clear, would i need to get 2 x Xtend 900 1 Watt RSPMA? or is there a receiver module? – Riley Lloyd Dec 27 '13 at 16:31
TI is claiming that their RF high performance chips can go up to 25km. See their RF Performance Line page that includes the CC1200 device that claims that range.
In the real world you can not always attain that because of various factors like multipath fading. But since you are using a quadcopter and it is elevated most of the time, the effect of multipath fading will not be as bad compared to a system that has 2 transceivers talking to each other while both elevated 5ft above ground.
- 17,131
- 37
- 56
- 91
- 194
- 3
