I have an output pin configured to be either open-drain or hi-z. How can I use my multimeter to tell which mode it is in?
Asked
Active
Viewed 1,710 times
Can you make sure the output value is low while you do the test? – The Photon Dec 23 '13 at 18:02
Also, what device are you using? Is it a microcontroller or an FPGA or something else? A link to the datasheet of the device would give us the most information to help answer your question. – The Photon Dec 23 '13 at 18:05
I am using an STM32F103 microcontroller. – Hesky Fisher Dec 23 '13 at 18:52
If the pin can only be high impedance or open collector then you can add a pullup resistor to the pin and try to write a logic 0
to it, If the pin voltage goes low it is open-collector, if it stays at a high voltage then it is high impedance.
Joe Hass
- 8,447
- 1
- 29
- 41
