I have created a C++ project for an LPC1227 using LPCExpresso 6.1.0. The project, up until now, builds and runs fine. I have not made any changes to cr_startup_lpc12xx.cpp.
I would like to add a SysTick_Handler(). In my main.cpp I have added a method:
void SysTick_Handler(void)
    timerCounter++;  // these variables are all declared globally in main.cpp
    timer_10ms_tick = true;
    if ((timerCounter % 10) == 0)  //every 100ms
        timer_100ms_tick = true;
    if ((timerCounter % 100) == 0)  //every 1000ms
        timer_1000ms_tick = true;
I have also add the following line in my main() method:
SysTick_Config(12000000/100);
When I run my code via debug, the interrupt is firing, but it is getting stuck in the default SysTick_Handler() that is inside of cr_startup_lpc12xx.cpp (which is just an infinite while loop). If I delete the default SysTick_Handler from cr_startup_lpc12xx.cpp, my program hard faults.
I have looked at the Blinky example (which is C, not C++) and it adds a new handler into main.cpp without deleting the handler from the startup file.
Can anyone suggest why my overriding handler is not being called? Is this a C++ difference?
TDL
  • 439
From https://rowley.zendesk.com/entries/20986562-LPC1114-IRQ-Handlers-in-C-work-in-C-do-not-work
You need to declare your interrupt handler as a C function otherwise the function will not override the default handler.
So for example you could do something like the following to make the declaration work in both C or C++:
#ifdef __cplusplus
extern "C" {
#endif
void irq_handler();
#ifdef __cplusplus
#endif
I assume changing irq_handler() in the code above to your SysTick_Handler code will then work. e.g.
extern "C" {
geometrikal
  • 4,921
  • 41
I don't know if this is true of C++, but in C the default handler must be declared as a weak function in the default declarations. This allows another declaration to override the original one, so your custom handler should not have the weak attribute.
Joe Hass
  • 8,447
  • 41
I had exactly the same problem once. Yes it is C++ vs C difference. Looks like the maintainers of LPC support libraries did not care for C++ developers. Full answer is here Bug in Keil ARM compiler with interrupt handlers and C++?
x4mer
  • 986
