I am working on a large FPGA design, and I am very close to the resource limits of the FPGA that I am currently using, the Xilinx LX16 in the CSG225 package.
The design is also almost complete, however at the moment it will no longer fit in the FPGA. I can turn off parts to get it to fit, however I need to reduce the resource usage in order to complete the design and have it meet timing and size requirements.
I would like to know if there are any tools our reports that can help me identify which parts of my design are consuming the most resources. My design is not partitioned, and is split over about a dozen or more VHDL modules.
Xilinx timing reports are fantastic, but now I need to know where I can get my best bang-for-buck in terms of space saving.
I also have a hard time telling which type of resources I'm running out of, or what effects those resources.
Another annoyance is that as the design gets larger, components that used to meet timing are starting to fail because their placement is no longer as ideal.
Currently, I use the Post-Place and Route Static timing reports, and I use SmartXplorer. I'm using design strategies to optimize for timing.
After turning off part of my design to get it to fit, here are some of the results:
slice register utilization: 42% slice LUT utilization: 96% number of fully used LUT-FF pairs: 38% Does this mean I'm light on registers, but heavy on gate usage?
Are there tools to help developers optimize for area, or at least give them more insight into their code?
Update: After looking at the Module Level Utilization, I found out that I had small glue async fifos all over the place that take up about 30% of the total LUTs. I am using them as cross-clock-domain glue for high speed buses. I should be able eliminate these, since the clocks are tightly related. (120 MHz input, produces 100 MHz and 200 MHz through DCMs)
