So I'm interfacing an arduino with a Melexis temperature sensor, and it's going okay--aside from the fact that I can't seem to get the CRC check to work.
I've gotten read operations to complete successfully (although my software ignores the packet error code) but I have tried a lot of implementations of CRC8 to check the PEC byte to no avail. The code block I am using now came from OneWire:
uint8_t OneWire::crc8(const uint8_t *addr, uint8_t len)
uint8_t crc = 0;
while (len--) {
uint8_t inbyte = *addr++;
for (uint8_t i = 8; i; i--) {
uint8_t mix = (crc ^ inbyte) & 0x01;
crc >>= 1;
if (mix) crc ^= 0x8C;
inbyte >>= 1;
return crc;
I rewrote it to consider just the one byte:
int smbCRC(int message) {
uint8_t crc = 0;
uint8_t inbyte = message & 0xFF;
crc >>= 1;
inbyte >>= 1;
return crc;
But its CRC does not match that of the MLX datasheet (Figure 8 from here for example). When I print an int with its CRC8 like so:
int message = 0x3aD2;
lcd.print(String(message,HEX) + " " + String(smbCRC(message),HEX));
I get back "3ad2 eb", though the datasheet says the correct PEC is 0x30. Where am I going wrong? It seems like this could be caused by a bad implementation of CRC or bad assumptions on my part about the CRC input, and I'm not sure where to start troubleshooting.
