What would be the difference in using a 7-segment decoder with active-high outputs vs active-low outputs, to driver an LED display?
Asked
Active
Viewed 324 times
Some 7 segment displays are common anode, which require a decoder with an active-low output. Others are common cathode, which require an active-high output. Choose the decoder appropriate to the display that you want to use.
MattyZ
- 2,926
- 1
- 22
- 23
@stevesy It seems common-anode displays are more common, as the decoder circuitry in bipolar 74xx series devices drew more power when driving common-cathode displays. Whether this is also the case with CMOS decoder ICs like the 74HC/HCT series, I am not certain. – MattyZ Dec 06 '13 at 05:51
