I searched around the forum and found this post: Analog voltage level conversion (level shift)
I built a dinamic motion seat with an Arduino, H-Bridge and 2 wiper motors. The wiper motors are acting like a servo because I mounted a potentiometer to the motor output shaft.
Now my motors will turn only about 180° which will result in an analog voltage from 1.6V to 3.5 Volt.
I've built this circuit:
on a little PCB like this:
From my understanding I can use the bottom potentiometer to set offset voltage 1.6V then move the pot to the maximum position and set the Vout with the upper pot to 5V.
Now the output should be 0-5V at 180° pot movement. I use LM324n and 10k pots. Now the problem is that there is no amplification. I only can lower the voltage at Vout but max is 1.6V too.
Maybe my PCB is built wrong but I've checked it many times. Or did I understand something wrong and this is impossible?
