I am designing a heater circuit that will be used in a product to be produced in small to medium quantities (hundreds to thousands of units, not tens of thousands). This heater will be PWM controlled to maintain a set temperature in the heated medium, however as an additional safety measure I would like to include a separate over temperature cut-out to prevent fires or high surface temperatures in case of a fault in the control loop (failed sensor, switching FET shorts out, load is removed from the heater element etc. etc.).
The cut-off should return to an operating state once the over-temperature condition is resolved (ie. normal, trip-once thermal fuses are not appropriate). Ideally the solution would be as simple as possible and contain few parts, the device would be used in remote locations so reliability is a concern.
The heater would be driven from 12V, maximum power would be 40W (ie 3.3A). The cut-off should operate at 50 to 60 degC.
The options I am considering and their relative merits are below:
a. Normally-Closed Bi-metallic Switches, placed in series with the heater element (eg. Klixon 7AM):
- For:
+ Simple, single component.
+ Seems to be the most common solution for this application.
+ Significantly more expensive than PTC (>$3.00/pc). - Against:
- I have not been able to find any surface mountable options.
- Has moving parts which raises reliability concerns in my mind although
they do seem to have quite acceptable lifetime ratings.
b. Positive Temperature Coefficient (PTC) Resistors, placed in series with the heater element:
- For:
+ No moving parts.
+ Surface mountable.
+ Cheap (less than $0.40/pc). - Against:
- Generally designed for use in over-current protection and data is given to suit
eg. available data does not give resistance vs temperature curves.
- Temperature trip point would be dependant on current through the resistor.
- Few options available for use over 3A.
c. Temperature Switch IC (eg. Analog ADT650x Series) driving a FET:
- For:
+ No moving parts.
+ Surface mountable. - Against:
- Multiple parts (reliability).
- Additional design work (ok, it's negligible but I'm lazy).
- Requires additional power supply (5v).
- Total BOM cost is similar to bi-metallic switch.
My questions are:
- Any feedback on the merits of these options?
- Can anyone suggest alternative options for implementing this cut-off?
- Is anyone aware of any PTC resistors designed for this usage or higher current applications?
