I was wondering if you can use an inductive proximity sensor to detect aluminum or if a capacitive sensor must be used? I wasn't sure if inductive sensors were reserved for ferrous metals only.
mad_z
  • 5,050
  • 45
  • 56
user337
  • 361
I've used years ago an inductive proximity sensor for a test, and I remember that it sensed aluminium and copper way better than iron.
Just found this doc.
Electric_90
  • 2,112
Axeman
  • 3,498
Yes - inductive sensors work on the same principles as a comercially avaliable metal detector. They have an LC circuit which oscillates in a particular frequencey range, when a conductive material is near by, eddy currents form in the material which then produce their own magnetic field which then dampens the oscillation of the sensor.
SaM
  • 902
