I pursue an experimental project that comprises the development of a car GPS navigation unit and software for it.
We develop and test the software on a working laptop-based prototype which has a USB-GPS (mouse GPS) connected to it. So far this setup has been satisfactory for our development needs.
We planned to assemble a beta-prototype based on a small micro-PC with attached peripheral devices (touch-screen, USB-GPS, etc.) to achieve something like this
But recently I started to think about assembling the whole system into one body which is integrated with a touch-display, like it is done with a regular car GPS devices.
However, I do not know where to start. I do not need any custom PCBs, so the other answers on StackExchange are not quite relevant (they are relevant to custom-designed devices like Pebble or AlarmClock, or Oculus Rift)
Instead, I am only interested in putting a small PC-compatible computer and a GPS unit inside a simple touch-screen body. Is that actually possible?
  • are there any ready-made device bodies that can be purchased?
  • is it possible to avoid any custom-designed fabs and just assemble such a device from off-the-shelf components?
skanatek
  • 123
  • You can certainly get industrial micro-PC cases, or various plastic or metal "project boxes", is that what you're looking for? – pjc50 Nov 08 '13 at 13:17
    I realize this is a lateral-thinking alternative rather than a direct answer, but have you considered using a cheap no-name smartphone or tablet, perhaps something off AliBaba.com or such? They have touchscreens, many have integrated GPS, and they are programmable in various high level languages. Various sizes too. – Anindo Ghosh Nov 08 '13 at 13:32
  • @AnindoGhosh -- great comment. In fact, the device will probably need to compete with the "app" market. – Scott Seidman Nov 08 '13 at 13:44
  • http://www.inhand.com/products-services/hydra/ – Scott Seidman Nov 08 '13 at 13:56
    I don't get the close votes. Manufacturability of electronic products is a huge electrical engineer's problem, and by definition, a design issue – Scott Seidman Nov 08 '13 at 13:58
  • I agree that this is an important issue, but as stated this is still waaaaaaay too broad. Not even close to answerable within a SE format answer. Chop it up into smaller specific design questions and I along with many others will be more than happy to help you. We don't want to give just handwavy general advice, we want to give advice that will actually get you and others reading the site further in the design process. General advice on the issue is already plentiful on the internet and a waste of our time. – user36129 Nov 09 '13 at 06:56
  • user36129, the answer provided by Scott is actually very valuable. How can a person know that a case or a body for a custom device is called 'electronic enclosure'? I think that this question/answer pair will help the other beginners like me to get the basics of the process. – skanatek Nov 09 '13 at 19:03
Yes. The search phrase would be "electronic enclosures", or "enclosures" if you're already within an electronics supply house's site, like digikey. This should tell you who the big players are, and then you can search the manufacturers site for semi-custom options if your quantities are big enough to make that path worth it.
Again, yes. Anything is possible. There are many forms of single-board computers that you can center the prototype around, with all sorts of form factors, that will let you do this. The question, of course, is "is this the right way to go?" If you're shooting for a proof-of-concept prototype with a "does this work" type of answer, it makes little difference. If you're prototyping to see if you can make it fit into a certain required form factor or size, the boards you select will have a huge impact. If you're really prototyping so as to scale up to production volumes, now you're entering a "design for manufacturability" stage.
Of course, there's the matter of what your sale price needs to be, and can your manufacturing costs enable that price. Find your boards, and find out what sort of licensing and OEM agreements you can reach with the manufacturer. You want to consider what will happen if your supplier goes out of business -- can you make your product live on? There are obvious tradeoffs to having other manufacturers of value-added products beyond simple components in your supply chain. You can get off the ground faster and less expensively, with less design effort, but cost may be higher (or lower) and you can introduce instabilities.
I recommend you take a gander through Ulrich and Eppinger, Product Design and Development, for a quick intro to some of these topics. If this is a business venture of some importance, you might want to scrape up budget for a consultant who can help your product meet your needs.
Scott Seidman
  • 29,274
  • 44
  • 109
  • Thanks, Scott! I should say that the recommendation to search for 'electronic enclosures' was really important to me. – skanatek Nov 09 '13 at 19:01
