I want to use an RF12B to communicate over radio with an Arduino, but the transceiver is rated at 3.3 V. I hear I need to use a voltage level shifter, but what do these look like and where can I find a schematic to help me hook it up?
Asked
Active
Viewed 1.2k times
http://electronics.stackexchange.com/questions/708/i2c-3-3-to-5-0-v-conversion http://electronics.stackexchange.com/questions/622/bi-directional-step-up-and-step-down-3-3v-5-etc – Toby Jaffey Jan 08 '11 at 14:24
Microchip has this document with 19 tips about mixing 3V and 5V parts in a circuit (not just level shifting).
The tips:
- Powering 3.3V Systems From 5V Using an LDO Regulator
- Low-Cost Alternative Power System Using a Zener Diode
- Lower Cost Alternative Power System Using 3 Rectifier Diodes
- Powering 3.3V Systems From 5V Using Switching Regulators
- 3.3V → 5V Direct Connect
- 3.3V → 5V Using a MOSFET Translator
- 3.3V → 5V Using A Diode Offset
- 3.3V → 5V Using A Voltage Comparator
- 5V → 3.3V Direct Connect
- 5V → 3.3V With Diode Clamp
- 5V → 3.3V Active Clamp
- 5V → 3.3V Resistor Divider
- 3.3V → 5V Level Translators
- 3.3V → 5V Analog Gain Block
- 3.3V → 5V Analog Offset Block
- 5V → 3.3V Active Analog Attenuator
- 5V → 3V Analog Limiter
- Driving Bipolar Transistors
- Driving N-Channel MOSFET Transistors
stevenvh
- 145,145
- 21
- 455
- 667
There's a couple of ways to to voltage level shifting, depending on how fancy you want to get. Just to name a single manufacturer, Texas Instruments has a whole section devoted to mixed-voltage interfacing between different protocols. You can almost guarantee that there's a chip that will fill your needs.
Alternatively, as pointed out in this answer, SparkFun makes a small board that will probably be the easiest solution to implement. Your radio appears to use SPI, which should be workable with that board.
It depends what direction the signals are going to.
- If the 5 V device is going to drive a signal on the 3.3 V device, use a simple resistor division.
- If the 3.3 V device is going to drive a signal on the 5 V device, you could use two inverters with the last stage tied to 5 V. However, this requires four resistors and two transistors, which is quite an expense. You could also try out the implementation as shown in Sparkfun's breakbout board.
- If the signal is bidirectional (I²C), maybe something in this appnote on page 10 will work (seems similar to what Sparkfun is using).
Peter Mortensen
- 1,676
- 3
- 17
- 23
Hans
- 7,238
- 1
- 25
- 37
