I have a 32MHz MCU (Atmel XMEGA A4) and I need to recover a digital signal coming from a GPS front end chip which is outputting SIGN and MAGNITUDE data at 16.368MHz. Clearly this is a hell of a task for the XMEGA running at only 32MHz. Is there any way that this is possible?
I ultimately want to save the data in a compressed form to some memory. I'd like to convert the 16.368MHz data stream to I/Q samples at baseband (0Hz IF). Using some DSP techniques this is quite feasible, I could filter the incoming data and then downsample (keep every M'th sample and discard all others). This could be done in a reasonable number of clock cycles although it does seem like a bit of a task for the 32MHz XMEGA.
So is an MCU even the right tool for this job? I've chosen this one because the final application is a battery powered device and every nanoCoulomb needs to be conserved. With this in mind, if there's no good way to accomplish this with the XMEGA, should I maybe be looking at some kind of DSP chip? Or possibly a low power FPGA?
MattCochrane
  • 356
  • How long is the sequence you want to capture? – johnfound Oct 29 '13 at 15:05
    Are you sure that's the right frequency? http://www.st.com/web/en/catalog/sense_power/FM1934/catalog/mmc/FM1934/CL1942/SC612/PF246472 downconverts to 4MHz. You'll probably require a DSP anyway; is there a good reason not to build around a reference GPS implementation? – pjc50 Oct 29 '13 at 15:07
    As slow as GPS updates, there is no reason there should be a 16MHz data stream. – Matt Young Oct 29 '13 at 15:15
    @MattYoung: The bandwidth of the raw spread-spectrum GPS C/A signal is on the order of 8 MHz. Clearly, the OP is attempting to record the raw IF signal so that he can do software-defined radio and apply advanced post-processing techniques for maximum precision. – Dave Tweed Oct 29 '13 at 16:02
  • @pjc50, It's actually this chip [link](http://www.skyworksinc.com/Product.aspx?ProductID=987) but same deal. Downconverts to 4.092MHz IF but the sampling frequency is 16.368MHz. There is a good reason not to build around a reference implementation. I'm planning to save 'snapshots' and process them later on a computer to get a positional fix. This is all in the name of low power GPS tracking. You can get very low charge/fix with this method. – MattCochrane Oct 30 '13 at 01:11
  • @DaveTweek, That's right I'm post-processing the signal although I'm only tracking the C/A code so the signal bandwidth is only about 2.05MHz. – MattCochrane Oct 30 '13 at 01:14
    If you were to run an MCU at an integer multiple of your sampling frequency, and you could capture sufficient data using DMA (for which you probably need a substantially more capable MCU than an 8-bit Atmel toy), then you might be able to do it in an MCU; a carefully chosen Cortex-M4 or the like might be adequate. Otherwise, FPGA's are your friend. – markt Oct 30 '13 at 09:40
  • I'd use an FPGA – Synchrondyne Nov 08 '15 at 07:30
  • Can you not just ignore the data out of the GPS most of the time and get the XMEGA to sample it only at the 'M'th sample rate - a rate that your XMEGA can presumably handle? Just because the GPS produces data that fast, doesn't mean you have to process it at that rate. – Icy Nov 09 '15 at 08:42
I doubt your processor will be able to read data and store it in each cycle (given that the 16.368 MHz is more than half the 32 MHz clock, some inputs will have to be processed in sequential processor cycles.
A more powerful processor (e.g. Teensy 3.2) can run at 96 MHz, and with DMA may be able to process the inputs fast enough.
jp314
  • 18,395
Before You Even Think About hardware capacity or something like that, Did you remember the Nyquist theorem?
Only with that You would have to sample the signal at least twice its highest frequency, but we know that even twice is still not enough. Perhaps based on this argument you'll see that faster hardware is required.
  • Good to remember Nyquist theory, but its probably not the over-riding issue here - we don't have any information about how fast the signal that the GPS is reporting is changing, but it's probably not that fast, the real issue seems to be simply the data rate out of the GPS. – Icy Nov 09 '15 at 08:39
