-2
I'm looking for ways to control power outlets (to turn them on/off) remotely and to schedule them.
This is not for my home, but for a larger exhibition hall.
So far I have found two different solutions, but I wan't to see if somebody maybe has a better solution.
  1. Install a permanent X10 based system. All outlets needs to be changed.
  2. Use something like a ShowMaster (Pros: Can control projectors, dim show lights etc. Cons: Don't know if it can control power outlets, devices that don't support dmx, serial, ethernet comm.)
So far, the best solution maybe is a combination of these two. Some devices is ok to just cut the power to with e.g. a X10 module, and others are better to control with the ShowMaster e.g. projectors and show lights.
But is there other good solutions out there.
eivindml
  • 49
Maybe the Digitalstrom system would satify your needs:
  • one seems to simply add a small screw terminal-like interface to the plug to be controlled
  • and a central control device.
Also it appears that the system is using an open communication standard permitting the development of custom control software: Digitalstrom Allianz
ARF
  • 5,169
  • 42
  • 69
