I am trying to create a custom data type which I am creating in a package using Xilinx ISE 14.5. I am trying to create a generic DEMUX to switch between buses, here is the code of the generic DEMUX:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.NUMERIC_STD.ALL;
use work.CustomDataTypes.all;
entity GenericDEMUX is
     -- Ancho del bus de cada salida y número de salidas
     generic( busWidth              : integer := 4;
                 channelsNumber     : integer := 4
    Port (  Output  : out  Matrix(channelsNumber-1 downto 0, busWidth-1 downto 0);
                Control : in     integer range 0 to channelsNumber-1
end GenericDEMUX;
architecture Behavioral of GenericDEMUX is
begin
end Behavioral;
So I created a Package to contain Matrix data type:
CustomDataTypes.vhd:
package CustomDataTypes is
    type Matrix is array (natural range<>) of STD_LOGIC_VECTOR (natural range<>);
end CustomDataTypes;
When I do Check Syntax on the Generic DEMUX I get this errors:
ERROR:HDLParsers:164 - "//vboxsrv/datos/Datos/Micro UTN/FPGA/MaquinaEstados/CustomDataTypes.vhd" Line 14. parse error, unexpected NOTCONSTRAINT
ERROR:HDLParsers:3009 - "//vboxsrv/datos/Datos/Micro UTN/FPGA/MaquinaEstados/CustomDataTypes.vhd" Line 35. Package CustomDataTypes does not exist.
I don't know what parse error, unexpected NOTCONSTRAINT means but I think it could be related to Package CustomDataTypes does not exist. Here is a Screenshot of what my Libraries tab looks like, as you can see CustomDataTypes.vhd is there:
However I don't see it in the design tab:
I tried adding it but it says it already exists.
Andres
  • 1,834
  • 51
Unfortunately not until VHDL-2008 were unconstrained arrays of unconstrained elements allowed.
In other words, for pre VHDL-2008:
type Matrix is array (natural range<>) of std_logic_vector(natural range<>);
Would have to become either something like:
type Matrix_n_by_8 is array (natural range<>) of std_logic_vector(7 downto 0);
Or use 2d arrays:
type Matrix is array(natural range<>, natural range<>) of std_logic;
apalopohapa
  • 8,419
  • 39
  • Wow that worked. So `type Matrix is array (natural range<>) of std_logic_vector(natural range<>);` is only for VHDL-2008 which Xilinx ISE doesn't support? – Andres Sep 30 '13 at 18:36
  • PS: How can I access the array in each index because `Output <= "0000"` gives `Wrong index type for Output` – Andres Sep 30 '13 at 18:43
  • @Andres Correct. I'm not even sure if Vivado supports any VHDL-2008. – apalopohapa Sep 30 '13 at 18:50
    @Andres PS: You access the 2-d array with a comma: m(0,0) <= '0'. You can define functions that make vector assignment easier. – apalopohapa Sep 30 '13 at 18:52
