In a lot of circuits, I've seen ferrite beads on the Vdd lines to microcontrollers. For my high speed dsPIC33F (80 MHz, 40 MIPS) microcontroller, should I have ferrite beads on the Vdd lines or should I not bother? The datasheet doesn't suggest using them. I'd like to limit EMI/RF interference, as the module will be used on a model plane and this type of interference could cause problems for the onboard radios.
Asked
Active
Viewed 1,822 times
To filter high frequency noise. Inductors' windings are capacitive at high frequency so they are effectively useless. If you're worried about your circuit affecting other circuits (or being affected by them), I would only filter the I/O and power entry to your module, so that conducted noise doesn't leave your module on the I/O and power lines, which can act like antennas and radiate the noise, or pick up noise from other modules. The other use, inside a module, is for sharing a voltage rail with sensitive analog components, such as an ADC with a micro. In the case of your PIC, it usually doesn't need such a thing.
bt2
- 3,784
- 2
- 25
- 28
2it can help you pass FCC cert to use it on places like pics, you want to use caps to filter first, as a ferrite does not do well against high power transients, it operates on absorbing low power transients. – Kortuk Dec 25 '10 at 17:55
2Ferrites != Inductors : Ferrites are not inductors! Ferrites generally have very few turns, so interwinding capacitance is not important. Also, ferrites are dissipative, rather then inductive, so high frequency energy passing through a ferrite bead gets converted to heat, rather then simply reflected back. This is why they are commonly used for high frequency applications. – Connor Wolf Dec 26 '10 at 05:34
2Furthermore, if your dsPIC has separate digital and analog power connections, a ferrite between the digital and analog connections (With caps on both sides) is likely a good idea. – Connor Wolf Dec 26 '10 at 05:39
