A few people have advised me to never solder a power cord directly to a PCB, but they couldn't explain why not. Why can/can't I solder it directly?
5Main reason is safety. Yanking out the power cable isn't as dangerous if it's a proper socket. That said, it's common to see directly wired stuff in retail products, but they use cable crimps and slack to help increase safety. I'm sure someone else can provide a much better answer, though. – Polynomial Sep 04 '13 at 09:14
The insulation on the cable may not be specified for the soldering temperature, and may be damaged.
The insulation is selected for electrical isolation, flexibility and thermal properties. These properties may change if the insulation is taken beyond the storage temperature limits. Damaged insulation may be considered to be non-existent insulation.
The flexibility of the cable will be affected by the soldering, as solder typically wicks some distance up the copper.
The restraint of the cable inside the equipment is typically redundant; a cable gland or clamp, followed by a screw terminal clamp on the copper end. The restraint design depends on the strength of the cable.
The strength of a copper conductor, stranded or solid, is reduced by soldering, as some of the diameter of the copper changes from copper to a copper tin alloy.
The current rating is also affected.
The gasses released by the insulation during soldering may be harmful to the person doing the work.
My opinion is that it is fine to solder directly, as long as the additional risks are compensated for in some way; derating, additional insulation, additional anchoring, and good airflow during soldering.
- 1,276
- 6
- 12
4additional insulation could be: [Heat-shrink tubing](http://en.wikipedia.org/wiki/Heat-shrink_tubing) | additional anchoring could be: [pcb cable strain relief](http://farm4.static.flickr.com/3494/3969642876_2b51cf3284.jpg) – m.Alin Sep 04 '13 at 10:48
1Polyolfelin heat-shrink tubing isn't usually accepted for safety-critical mains insulation (it's a physical barrier but isn't recognized for electrical insulation) – Adam Lawrence Sep 04 '13 at 12:14
good read. I was more afraid the conductivity of lead isn't that high (only 7% compared to copper) so soldering is good for 'signal' conduction in electronic circuit, but for power connection (much current) there may be much resistance causing voltage drop or heat. I think some kind of mechanical contact using screw will be proper. yesterday I gave up repairing a broken multi-tab because it was hard to solder a power wire(stranded) to a metal plate. I heard I need solder lead with aluminum,nickel,..alloy for this kind of soldering(normal lead would not adhere to the metal). – Chan Kim Jul 22 '21 at 05:31
Thanks. Usually the added solder increases the conductivity, comparing the (a) original copper against the (b) very slightly thinner copper but substantially increased thickness of solder. It is easy to measure the effect with a low resistance meter. – James Cameron Jul 24 '21 at 05:16
No great reason not to if you do it properly, lots of kit has power cables soldered to the PCB, both mains & low-voltage. Even stuff that has an IEC socket or similar on the back will have jumper wires to bring the mains to the board.
Several important factors are mentioned in James Cameron's answer, cable strain relief being a major one IMHO. Many of the rest are a bit pedantic as most cables will be fine with being soldered to something - admittedly if you were producing a million mains-powered widgets that had to pass safety certification you'd probably need to demonstrate a bit more care, but in reality for the odd project it'll be fine.
- 7,041
- 2
- 21
- 34
Agreed, many are pedantic, but I couldn't tell if the original poster planned to produce millions. ;-) – James Cameron Sep 04 '13 at 10:51
no , solder is soft metal in fault conditions, all wires need mechanical fastning ie so solder to pcb needs wire lugs (which has crimp and solder cup), and stranded wire lose mechanical properties all industry standards dont allow it. and if it was LV circuit you might see manslaughter charges up to 25 year in prison if causing death?
- 21
- 1
Do you mean a crimp connector that is soldered to the pcb, so the cable is crimped, perhaps with solder also, to the pcb? – Nick Oct 23 '21 at 12:32
