everyone. I am researching into the "holding" of electricity. I found out about capacitors, but I am not sure that I understand. If you charge a capacitor with a battery in a circuit like this:
, disconnect the capacitor, then connect the capacitor into a circuit like this:
simulate this circuit will the capacitor power the LED? If not, then how so? Any answers are appreciated.
Justin Chang
  • 147
  • "(please disregard the charges of the battery, capacitor, and LED)" ... What? – Ignacio Vazquez-Abrams Aug 29 '13 at 01:56
  • A suggestion: Add a current limiting resistor both for charging the capacitor and for driving the LED, and try this for yourself. It is a trivial experiment. You might be surprised at how long the LED stays lit with even a small capacitance. – Anindo Ghosh Aug 29 '13 at 08:06
Yes, it will light the LED up but for a very short time.
The amount of energy stored by a capacitor is:
\$E=\frac{1}{2} C V^2\$
E is the energy stored, C is the capacitance of the capacitor, and V is the voltage across the capacitor.
For a 1uF capacitor charged to 9V, that is 40.5 uJ.
In addition to this, typical LED's have a forward current drop of ~2-3V, and capacitors typically have lower internal resistances compared to batteries. This means that you're going to get a very high current for a very short time, which could damage your LED.
Suppose you did limit the output current to 10mA (typical for small LED's), and the LED has a forward voltage drop of ~2V.
That means the LED would stay "lit" for (assuming we could extract every last bit of energy at the same rate from the capacitor):
\$ \frac{40.5uJ}{2V \cdot 10 mA} = 2.025 ms \$
Which is a very short time indeed.
helloworld922
  • 16,600
  • 87
  • what does the e c and v stand for in your equation for the energy of the capacitor – Justin Chang Aug 29 '13 at 02:20
  • E = energy, C = capacitance, V = voltage – helloworld922 Aug 29 '13 at 02:26
    Key point: A typical indicator type LED with a nominal 20 mA current will stay quite visibly lit all the way down to 0.5 mA or less. See [my answer here](http://electronics.stackexchange.com/a/80368/14004), where I have a shot video showing how much longer an LED stays lit than calculations would indicate. – Anindo Ghosh Aug 29 '13 at 08:05
  • True, but even still the time the LED could theoretically stay on is on the order of hundredths of seconds. Still a very short time. – helloworld922 Aug 29 '13 at 16:25
The capacitor will power the LED until it no longer has enough voltage to do so, unless the current being drawn from the capacitor is sufficient to destroy the LED.
  • 48,282
  • 73
  • 102
