Sounds like a stupid question, but really hasn't been asked before, or I haven't found a post about it. Either way, here it is:
I bought a soldering iron recently and am looking for a place in my house to do my soldering. Of course the first thing in my mind would be to solder in the basement or garage and as close to a window/outdoors with good circulation, however I plan on working with arduino boards and would like to everything in my upstairs "computer room" near my gadgets. Do you think opening up my window in my room and having a fan suck out the fumes aimed at the window would be suffice to be safe, or should I stick with the basement/garage idea. Let me know on your thoughts.
ProspectiveEng
  • 197
Near a window with a fan sucking the fumes out the window would be better fume technique than most non-professionals would use. Unless you're particularly sensitive, or asthmatic it should be more than good enough for the low volume infrequent soldering you'll be doing. Personally, I'd be more concerned about the iron as a fire hazard.
Scott Seidman
  • 29,274
  • 44
  • 109
    I live in AZ, soldering with the window open is not all that feasible ;) – Kris Bahnsen Aug 20 '13 at 20:48
    Can't tell you how many old electronics techs, who do plenty of (periodic) soldering, doing their work in tiny unventilated closets. I guess all the young ones just die ;) – Scott Seidman Aug 20 '13 at 20:54
    haha! I started soldering when I was rather young, 11-12, and made myself super paranoid about it. It has stuck with me all these years. – Kris Bahnsen Aug 20 '13 at 20:57
    Also, if a day of soldering is planned, drinking plenty of fluids will abate most of the irritation in your from inhaling the fumes. Tea works for me as its give your eyes a rest periodically too while you make it. Too many times has a "quick" solder job turned into an afternoon of attempting to repair everything on the shelf. ;) – SLaG Aug 20 '13 at 21:23
I've been soldering in poorly ventilated rooms for years and I'm still alive.
I think the sociopathy is unrelated, probably related to age or unprotected contact with Javascript.
John U
  • 7,041
You need good circulation. Flux is noxious when it burns (and only slightly less so when not burning), and you need to use flux.
Ignacio Vazquez-Abrams
  • 48,282
  • 73
  • 102
  • In your experience, where do you do your soldering, if done at home? with that in mind, My scenario in my room wouldn't be ideal because of the lack of circulation. – ProspectiveEng Aug 20 '13 at 20:22
    It's not _that_ bad, it's only a small plume of smoke and it doesn't linger as badly as tobacco smoke. Computer room with open window is fine, although keep it away from piles of flammable paper and don't drip solder on the carpet. – pjc50 Aug 20 '13 at 20:36
  • I do it in my living room, over a sheet of glass. But I have a small apartment so ventilation is easy. – Ignacio Vazquez-Abrams Aug 20 '13 at 20:38
Good circulation and a fume extractor/absorber. I use one of these guys: http://www.amazon.com/Weller-WSA350-Bench-Smoke-Absorber/dp/B000EM74SK/ref=pd_sim_sbs_hi_1
There are also smaller ones available that can be put right above the work area to absorb more: http://www.amazon.com/dp/B00012YSDW/
Carbon activated filter takes a lot of the fumes and chemicals out of the air. Also helps to turn on a ceiling fan, or your HVACs fan and get good air moving around.
Kris Bahnsen
  • 1,758
