I used 3.3v microcontroller. I want to add TX LED and RX LED communication on RS232, RS485, TTL/CMOS.
My question:
Led communication must be mounted as SINKING or SOURCING on I/O microcontroller for avoid interfere in communications?
Picture in here: Datasheet
new bie
  • 237
  • Whats your question? – Kris Bahnsen Aug 13 '13 at 23:32
  • Led communication must be mounted as SINK(pull down) or SOURCE(pull up) on I/O microcontroller for avoid interfere in communications? – new bie Aug 13 '13 at 23:38
    What about your set-up would make it interfere either way? – The Photon Aug 14 '13 at 00:29
  • Are you asking which, sink or source? Or, sink/source, versus something else? What exactly do you mean by "SINK" or "SOURCE"? How about a schematic? – Phil Frost Aug 14 '13 at 01:10
  • The question is not pointeless; it's entirely possible that a line driver drives "high" or "low" better than in the other direction - however, changing the arrangement will change the "sense" of when the LED is on, which may not be desired. – Chris Stratton Sep 10 '13 at 21:06
RX and TX lines at TTL signals** between the μC and the line driver IC*** is a good place to connect the LED indicators. There's no good reason to connect the LEDs to RS-232 lines. RS-485 lines are bidirectional, so the LEDs alone wouldn't tell if the data is TX or RX on RS485.
** 0 to 3.3V serial
*** RS-232 or RS-485 line driver, and such
Back to TTL signals. You can connect the LED between signals and GND **, or between signal and Vcc ***. Either would work as long as the LED current is low enough (limited by a series resistor). LEDs add some capacitance, which might be a problem at high speeds above, say, 1M bits per second.
** source in the O.P. terminology
*** sink
Nick Alexeev
  • 37,739
  • 230
