How close can I place two 0603 resistors on a PCB?
Kortuk
  • 13,362
  • 60
  • 85
cksa361
  • 3,814
  • 49
I have a silk layer bounding box of 2.6mm x 1.4mm around the pads of 0603s, and I often place resistors with touching bounding boxes. Lengthwise placed next to each other this leaves 0.2mm between pads. For reflow soldering this has never caused problems. For wave soldering you will need more space, esp. in the wave direction. For hand soldering it depends on the soldering skills of the person who assembles the board. 0.2mm may be possible if you don't use too much solder.
While 0.2mm may look like very tight, remember that this is reflow soldering. When the solder paste melts it's capillarily drawn to the contact surfaces of the resistor, so it won't flow to adjacent pads.
stevenvh
  • 145,145
  • 455
  • 667
If you need several resistors with the same value as close together as possible, use resistor arrays instead of individual parts. They save a lot of space.
Leon Heller
  • 38,774
  • 60
  • 96
    I think I got better than a 50% space savings per part by using 4x0402 arrays instead of discrete parts – Nick T Dec 15 '10 at 21:44
    The `law of conservation of misery` says that the other resistors with the same value are the completely other side of the board :-( (OT: stronger law than conservation of energy or momentum, BTW; another observation of this law is that every wire cut to measure is too short) – stevenvh Dec 16 '10 at 16:40
This can vary a lot.
Fab
How is it being soldered? By hand or pick and place? What fab house are you using? What are their requirements?
These are things you should ask yourself and get answers for in order to determine how close is possible for the fab process.
Signal Integrity
You will also need to look at what signals are on each resistor. When you have high speed lines you can have issues. Also if you have high voltage you can have issues.
I know this is rather broad. If you have a specific case I will be willing to add more.
Kellenjb
  • 17,509
  • 51
  • 87
    When you place a resistor down, you are effectively putting the wire a little higher above the ground plane. When you do it with two devices near each other you will get both devices having increased cross-sectional area next to each-other, but gaining inductance and a large portion a mutual inductance. This can hurt signal integrity a lot, as you will bounce the other traces signal. @kellenjb, just expanding on your signal integrity section a bit. – Kortuk Dec 15 '10 at 00:24
From here "The document is "IPC-7351A Generic Requirements for Surface Mount Design and Land Pattern Standard". You have to buy it from www.ipc.org." You CAD package may have it already. There are 3 variantes, so you would use the "least" (i.e. smallest one).
"If you want to look at the recommended footprints, without buying the standard, you can download a free viewer at: http://landpatterns.ipc.org/default.asp
There's more info available at: http://www.ipc.org/ContentPage.aspx?pageid=4.6"
Brian Carlton
  • 13,252
  • 43
  • 64
    Direct links: [dis'vun](http://www.techstreet.com/cgi-bin/detail?doc_no=IPC|7351B&product_id=1725406) and [dis'vun](https://portal.ipc.org/Purchase/ProductDetail.aspx?Product_code=987caa7f-ff93-df11-9e60-002219545fd5). – tyblu Dec 15 '10 at 19:10
    [Mentor Graphics' LP Wizard](http://www.mentor.com/products/pcb-system-design/library-tools/lp-wizard/) is IPC-compliant and has a 10-day trial. – tyblu Dec 15 '10 at 19:15
