I'm currently working on a system that requires an RF rangefinder with ~15 cm precision, over a range of about 50 meters. My research into the field has shown that I'll need complex and expensive electronics, clocked at nearly 2GHz, to get anywhere near my desired accuracy. 1 / (time for light to travel 15 CM)
. My question, then, is what method do IR rangefinders (the simple little ones for hobby robotics use) use to accomplish the centimeter precision that they display in such a small, inexpensive package? Is the method that they use something that could translate to RF to power my project?
Background info:
I'm trying to localize an aircraft within a defined box for autolanding purposes (think home-grown ILS localizer). So, I'm currently thinking about the system described here, where the aircraft has a small repeater to throw back any received signals, for a time-of-flight range calculation. 3 ground beacons arranged in a triangle, and you have X,Y,Z coordinates. Obviously IR as a medium is out, because the systems needs to operate in broad daylight, over 50 to 100 meters. I considered using an RF signal strength based rangefinder (beacon on the aircraft with a tightly controlled transmitting power), however between the RF noise from the motors and control systems and the trees and buildings surrounding my testing area, I don't think that is going to work within my required accuracy.
