I just tried desoldering an SMD receptacle off a mass produced main board of an IBM ThinkPad X41 laptop, but that beast stuck to the board like glue, and I destroyed it. Is it possible that the component was indeed glued?
feklee
  • 1,301
There are SMT unit process steps that use a wave solder machine to attach smaller (with isolated and separate leads) SMT components like resistors and capacitors. The device is glued down on the side where the wave will flow and when the PTH components are soldered the wave covers and solders the SMT devices. The devices are glued down as the board side that is being soldered is facing down.
Some manufacturers also glue down components that may shift during reflow soldering (like the case in your picture) especially if the component needs registration or alignment is critical and the part should not move during attachment.
placeholder
  • 29,982
  • 63
  • 110
Sure, it's possible. I do this myself when soldering larger SMT parts and there's no reason why a board manufacturer could not do it as well. Quite possible. Is it probable? Now, that's a different question...
Joe Hass
  • 8,447
  • 41
