One factor not yet mentioned is metastability. If a latching circuit is hit with a sequence of input/transitions such that the resulting state would depend upon propagation delays or other unpredictable factors, there is no guarantee that the resulting state will be a clean "high" or "low". Consider, for example, an edge-triggered flip flop which is currently outputting a "low", and has its input change from low to high at almost the same time as a clock edge arrives. If the clock edge happens long enough before the input change, the output will simply sit low until the next clock edge. If the clock edge happens long enough after the input change, the output will quickly switch once from low to high and stay there until the next clock edge. If neither of those conditions applies, the output can do anything. It might stay low, or quickly switch once and stay high, but it might stay low for awhile and then switch, or switch and then some time later switch back, or switch back and forth a few times, etc.
If a design is fully synchronous, and all the inputs are double-synchronized, it is very unlikely that a timing pulse would hit the first latch of a synchronizer in such a way as to cause it to switch at the perfect time to confuse the second latch. In general, it is safe to regard such things as "just won't happen". In an asynchronous design, however, it is often much harder to reason about such things. If a timing constraint on a latching circuit (not just flip flops, but any combination of logic that would act as a latch) is violated, there's no telling what the output will do until the next time there's a valid input condition that forces the latch to a known state. It is entirely possible that delayed outputs will cause the timing constraints of downstream inputs to be violated, leading to unexpected situations, especially if one output is used to compute two or more inputs (some may be computed as though the latch was high, others as though it were low).
The safest way to model an asynchronous circuit would be to have almost every output circuit produce an "X" output for a little while whenever it switches between "0" and "1". Unfortunately, this approach often results in nearly all nodes showing "X", even in cases which would in reality have almost certainly resulted in stable behavior. If a system can work when simulated as having all outputs become "X" immediately after an input changes, and remain "X" until the inputs are stable, that's a good sign the circuit will work, but getting asynchronous circuits to work under such constraints is often difficult.
