I have came across an Audi A4 2008 Quattro 3.2L, and in the glove compartment it an iPod dock. I took it apart and behind the iPod dock there is a PCB which connects to the ipod connector (which mounnted on another PCB) via 10 pins. This board has the following information: DEICE42143 V2R6-3 Zold SNZ0043525 F.-Dat 31/7
The car has a 12-pin connector (only 9 are populated) which is connecting to the above PCB. I looked all over the place for schematics/pinout of this module and did not find any information about it. I just wanted to hack in an AUX to it...
Anyone has any idea how I can figure out which pins are which on the 12 or 10 pin connectors?
Nick Alexeev
  • 37,739
  • 230
KingsInnerSoul
  • 829
  • You can look at audi wiring diagram to see which lines are going to the ipod unit. I'm not sure if it would have analog lines or what... – Marko Jul 15 '13 at 22:31
The pinout of the iPod 30-pin connector is the starting point from which you might be able to find the audio pins on the car side.
(Originally from here. You can also run a google search iPod 30 pin connector pinout.)
Nick Alexeev
  • 37,739
  • 230
    For a docking station I found this pinout that made more sense in my case http://pinouts.ru/CellularPhones-A-N/iPhone_connector_pinout.shtml – Sdlion Dec 05 '18 at 22:30
