I'm looking at an electrolytic capacitor (and old blue, Philips one used in electronics classes) and am wondering why it is printed with 4µ7-M.
I tried Googling, figuring that it was a common enough occurrence, but found nothing.
Is that supposed to be a 47µF cap? Why is the µ in the middle of the number? What is the -M for?
Thanks.
Synetech
  • 363
  • Thanks guys. I'm not sure I have seen this before (although the answers do seem vaguely familiar). The explanations for it also make sense. Thanks again. – Synetech Dec 08 '10 at 06:08
The "µ" symbol is put in place of the decimal point, 4µ7 translates to 4.7 µ farads.
Not too sure about the "-M" part tho - sorry
Jim
  • 3,325
  • 39
    This is correct. You will also see this on some resistors were it will say 4k2 and mean 4.2k ohm. – Kellenjb Dec 06 '10 at 16:14
    I suspect the M is probably some kind of indication of the dielectric temperature characteristic or voltage rating. It's probably a manufacturer specific code. – vicatcu Dec 06 '10 at 16:25
  • The "M" stands for tolerance code. J = +/-5% K = +/-10% M = +/-20% – Roman Dec 23 '20 at 11:06
Like Jim said, the µ indicates the place of the decimal point. This isn't restricted to capacitors, but also used for resistors and inductors:
resistor 31k6 = 31.6 kiloOhm
resistor 5M6 = 5.6 megaOhm
capacitor 2n2 = 2.2 nanoFarad
inductor 4µ7 = 4.7 microHenry
stevenvh
  • 145,145
  • 455
  • 667
    Beware people who use m for mega- and M for milli-. Not always that difficult to distinguish, but harder than (capital) S for seconds people. – Nick T Dec 06 '10 at 16:42
  • Good point, but most of the time this can be derived from context; 1m0 on an inductor will be milli rather than mega :-) – stevenvh Dec 06 '10 at 17:33
  • Most circuit simulation packages will also accept this format, but beware that they may not be case-sensitive, so a "1M0" resistor could work out as a 1.0 milliohm resistor, so use 1Meg in this case. – Martin Dec 06 '10 at 20:12
  • It gets even worse... Have you ever heard of a 100 uuF cap? That's micro-micro-farads. Nowadays, we call them picofarads. – Connor Wolf Dec 07 '10 at 00:37
It caused less confusion than sometimes arose with a decimal point, which was missed sometimes when documents were copied or faxed. That's not such a problem these days, but it is in common use, especially here in Europe. I always use that notation.
Leon Heller
  • 38,774
  • 60
  • 96
    I was more thinking about markings on components than documents, but you're right. However, in SMD markings a decimal point gets lost even more easily. – stevenvh Dec 06 '10 at 17:35
    And in some European countries, a comma is used instead of a decimal point for the seperation of the fractional part, and a point is used for seperating out the thousand part instead of a comma. – Martin Dec 06 '10 at 20:14
  • @Martin: in everyday use the comma is used in all of Europe, except for the UK. But I've never seen it on components – Johan.A Aug 08 '13 at 09:23
